Question about Dryers
Hampton bay redington 111 52 inch ceiling fan model 524606
Model 524606
SOURCE: Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Posted on May 27, 2008
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
SOURCE: Where can I find a Hampton Bay ceiling fan remote
Ebay is the best place to find stuff like this.
Posted on Apr 21, 2009
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
Electrical wiring guide for Hampton bay ceiling fan with remote control?
mcdevito75 here, I did a fast search and have a tech. support number -- 800-330-3267 Hope this helps.
Jul 23, 2010 | Hampton Bay 52 In. White Redington...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Changing the light in a 54shrl
Redington III. The remote receiver is integral to the light kit. There is no replacing the light kit, you can, however change out the glass, but you're stuck with what you got.
Apr 01, 2010 | Hampton Bay 52 In. White Redington...
I need to install a Hampton Bay ceiling fan Model AC552 but I have no instruction manual. Can I be emailed one.
look into the internet for download of that manual model with the full name of product for instruction manual. try that.
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'AzurĀ® Ceiling Fan
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Speed
The Receiver for the remote is defective. Try calling the toll-free number listed on the top of the motor housing of the safety label.
Jun 26, 2008 | Hampton Bay 52 In. White Redington...
Dryers Logo
80 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
