Question about KitchenAid KHHC2090S Stainless Steel 1200 Watts Microwave Oven
How do I change the light bulb on KHHC2090
I cannot remove the cover and diffuser in order to replace the cooktop lights.
  • KitchenAid Master
  • 9,047 Answers
It looks like that answer is on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it, your installation instructions, and parts lists here.
You can order parts here.
Posted on Oct 26, 2012
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
Can I replace the surface light switch on a SCA1000HBB microwave or do I have to call for service?
From the ever-handy owner's manual:
1. To replace the cooktop light/
night light, first disconnect the
breaker panel.
2. Remove the screw from the
side of the light compartment
cover and lower the cover until
it stops.
3. Be sure the bulb to be replaced is
cool before removing. Gently pull
the bulb from the receptacle.
Replace with a 12 volt, 20-watt halogen
bulb. Order WB36X10176 from your
GE supplier.
4. Raise the light cover and replace
the screw. Connect electrical
power to the oven.
Jan 14, 2010 | GE Microwave Ovens
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
KitchenAid KHHC2090S Stainless Steel 1200 Watts Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
