Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Total media backup may be damaged or incomplete
Error message when I try to open total media backup application from my desktop. Message "total media backup may be damaged or incomplete". Last back-up was 2010. This is my first use since 2010 with the same computer (macintosh/apple). The computer's original hard-drive has been replaced since last back-up. Previously backed up files are visible on drive so drive is working. Don't want to format drive as I'll lose existing back-up. Any advice on why I might be getting this message? Could it be because of the new internal hard-drive? and does this mean the recovery feature will not work for the 2009 files?
5 Suggested Answers
SOURCE: restoring backup files
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
Posted on Jan 05, 2008
mdsaeed67
  • 849 Answers
SOURCE: Why Are All Files Read-Only Now?
it happens when u swaped the system. format on new system will cure your problem. but the old files will remain the same.
Posted on Nov 26, 2008
  • 11 Answers
SOURCE: Simpletech 1TB USB not recognised properly
I had a very similar problem. It turned out to be a faulty case.
If the drive was formatted, there is a very good chance you've destroyed your data and may need professional services to recover the files (if possible)
Chances are you just needed to replace the external case by removing the harddrive from the simpletech case and installing it in a new case.
But again, if the drive's been formatted, it may have wiped out your data.
Posted on Aug 02, 2009
  • 10406 Answers
SOURCE: I have a 250 gb
> icon does not show up on the desktop or finder
A major "clue" that one component of the external storage device has failed, namely:
* USB cable (try a different one)
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure
* optionally, the external power-supply that connects to the enclosure
Use a multi-meter to verify the voltage/amperage output of that power-supply.
(Not all external storage devices need such a power-supply.)
> can it be saved?
Partially. Disassemble the enclosure, and remove the disk-drive.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage-device. (Compare it to a heart-transplant -- same body, new heart.)
Posted on Nov 04, 2010
Sim 3 installation
What causes Extended Attributes Are Inconsistent Error Message error? The Extended Attributes Are Inconsistent Error Message error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
Jan 20, 2014 | Computers & Internet
Hp pavilion a1102n winxp home. Blue screen after win splash logo, flashes too fast to read. 2x256mb. Dial up modem. Tried: removing modem, removing front usb FireWire media card slots. Removing one or...
Dear,
I saw your video and check the blue screen error. It comes for a friction of second and disappears but i kept my media player in slow motion mode and checked it. This error belongs to a missing registry file.
PERFORM THIS PROCEDURE for recovery.
A Stop 0xc0000218 error message means that a necessary registry hive file could not be loaded. This error message can occur if the file is corrupt or missing. To resolve this issue, you can reinstall the operating system and restore the registry files from a backup. The registry files may have been corrupted because of hard disk corruption or some other hardware problem.
This error message can also occur if the driver has corrupted the registry data while loading into memory, or the memory where the registry is loading has a parity error. In the latter case, turn off the external cache and check the memory chips.
To resolve this issue, follow these steps:
  1. Start your computer by running the Recovery Console, run the chkdsk /p command on the drive, and then restart your computer. Test to determine whether the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to step 2.
  2. When Windows loads, press SPACE BAR when the "Load Last Known Good" message appears.
  3. Complete a parallel installation, and restore the registry files from a tape backup. To do so:
    • Reinstall Windows in a separate folder.
    • Restore the damaged registry hive from backup. This procedure is specific to the backup application that you used to make a backup. Consult the documentation of your backup application or consult the vendor if you need assistance. Typically, this procedure requires you to restore a system state backup to an alternate location, and then copy the appropriate registry files to the %SYSTEMROOT%\System32\config folder of the damaged operating system.
    • If you do not have a tape backup, include the backup of network servers and production workstations.
    NOTE: If Windows is stored on a FAT partition, you can restore the files by using another computer and by copying the registry hive files to the %SYSTEMROOT%\System32\Config subfolder.
best of luck!
Mar 07, 2012 | HP Computers & Internet
My blackberry wont turn on, it has jvm error 545 message on the screen. is there anyway to fix this problem?
Looks like your Device Software has problem, you may have to reinstall your Device software. Hope you have recent backup of your data. If not, you may lose them!
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager
Hope this works.
Dec 06, 2010 | RIM BlackBerry Bold 9700 Smartphone
I have JUM error 102 on my blackberry pearl phone and now it wont power up, is there a way to fix it without having to replace the whole phone?
Try to put a good battery,if it still not working flash it with desktop manager and a new blackberry firmware.
Mar 20, 2010 | RIM BlackBerry Pearl 8100
Jvm error 547
Here is the procedure to resolve:
Step #1
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2
Make sure that you have installed updated device software installed in your PC.
Step#3
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
Open BlackBerry Desktop Manager.
Double-click Backup and Restore.
Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
Choose a location to save the backup file, then click Save.
Step#4
Click Next.
When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Jan 18, 2010 | RIM BlackBerry Pearl 8100
I get the message Uncaught exception: DSSMA: invalid state (5):10060 everytime I try to get my messages
Hi, When the BlackBerry smartphone user attempts to access or open the messages folder from the Home screen, the Uncaught Exception: DSSMA Invalid state error message is displayed. To resolve this error, you need to perform a hard reset of the BlackBerry smartphone. If you face the same error even after performing a hard reset of the BlackBerry smartphone, you need to complete the following steps: 1. Back up the BlackBerry smartphone using BlackBerry Desktop Manager. Erase all data and applications from the BlackBerry smartphone. Restore the backup of the BlackBerry smartphone using BlackBerry Desktop Manager. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | RIM BlackBerry 8800
NTVDM CPU fix
Hello there:
Something is amiss with your system.
That error message is associated with problems involving 16 bit
applications (Windows 3.x or MS-DOS) and both cmd.exe and regedit.exe
are full 32 bit Windows apps.
This sounds like it may be caused by an incomplete removal of one of
the trojans that blocks the use of Regedit.
You did not mention the specific products that you have tried. If you
have not previously used any of these you should try them:
Kaspersky Online Scanner http://www.kaspersky.com/virusscanner
Panda ActiveScan http://www.pandasoftware.com/activescan
Webroot http://www.webroot.com/
I highly recommend avg antivirus free version this is totally free and worked wonders for me
I hope that this is very helpful for you
best regards michael
Nov 16, 2009 | Dell Dimension 3100 PC Desktop
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
I am getting the error message jum102 on my cell phone what does that mean and how do i fix it
The BlackBerry smartphone stops responding, and the following error message is displayed:
"JVM 102"
There is an issue with one or more of the .cod files installed on the BlackBerry smartphone.
To resolve this issue, perform a clean reload of the BlackBerry® Device Software on the BlackBerry smartphone using the application loader tool.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  2. Double-click Application Loader.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  • Click Ok > Next > Finish.
  • When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  • To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
    1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
    2. Click Next.
    3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
    4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
    5. Click Next > Finish.
    Oct 07, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
    SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
    70 people viewed this question
    Top SimpleTech Computers & Internet Experts
    Gareth Cockram
    Gareth Cockram
    Lyle Siemens
    Lyle Siemens
    Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
