Question about Troy Garden
I have a 1 yr old big red horse mower quits after about 10 minutes..dealer replaced all filters and fuel pump..still quits for no reason..$2000.00 wasted no more troy bilt for me
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
If the Dealer didn't try this , then He's an idiot.
VENTING: Open the fuel cap a bit and see if that solves the problem. Many times the Fuel tank Vent will clog . This creates a vacuum as the engine tries to su.ck in gas. If the mower runs after loosening the cap.. then you need to find a way to clear the Vent ( usually in the cap).
Posted on Oct 26, 2012
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 374 Answers
SOURCE: My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Posted on Dec 19, 2009
  • 152 Answers
SOURCE: troy bilt mower 6.75 hp smoking too much oil...
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
Posted on May 25, 2010
  • 548 Answers
SOURCE: I have a Troy Bilt 675 lawn mower, won't start.
is the gas in the tank old? if so, try to drain it and put fresh gas in. Pull the spark plug to make sure it is not fouled and replace it or put in a new one. Check to make sure that you do not have the mixture or choke set to run too rich or too lean. If you are at an altitude above 2,500 feet you need to run more lean to compensate.
Posted on May 30, 2010
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Jan 03, 2017 | John Deere Garden
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
I have a John Deere Z820A 25 Horse Kawasaki. After about 45 minutes it acts like it is running out of gas. It will start again with the choke out, but won't run for long. I have replaced fuel...
I am an ex-z820a owner because these machines are terrible. Deere issued a PIP for these motors and maybe yours has not beed done yet. The best thing to do is get with a dealer see if the PIP has been completed then sell as fast as you can. I traded my z820a on a z920a and couldnt be happier.
Jul 26, 2011 | John Deere Garden
John Deere LA125 riding mower, three years old, 84 hours, Briggs 21 hp engine. I mowed the lawn. I cleaned the machine with a water hose. Now, IF it starts it will die after about 10 seconds. I took the...
Bought a new John Deere LA125 IN 08 only has 106 hrs on it, maintained it to a tee, changed oil etc, now it smokes, blue smoke, smells like burning oil, it does this when i rev up or down or when theres a load on the engine, but doesnt smoke all the time, i chaanged my plug which was amazing it would start it has the 21 horse briggs and stratten engine. Any help appreciated.
May 09, 2011 | Garden
I have a poulan pro 42 inch with the 18.5 horse briggs and stratton intek the motor runs good for about 15 minutes and then just quits???? I checked the oil, cleaned the air filter, replaced the inline...
When it quits remove the fuel line from the fuel pump to the carburetor and check if the pump is pumping gas while you turn the key to the start position with the brake locked. You could have a bad ignition coil.
Jul 30, 2017 | Garden
MTD mower runs for 10 minutes then quits.
I have the same problem with mine. I have narrowed it down to a fuel problem through deductive reasoning. Try this test. Start the engine clamp the bar (keep away from the spinning blade) when the engine tries to die push the prime bulb to keep it running. This simulates a fuel pump by putting a pressure higher than atmosphere into the float bowl spraying fuel into the intake. If this is the case the line (on mine it is a black tube) connected to the engine is clogged or what it connects to in the engine is not working properly. I am looking for a diagram of the carb and the engine that is detailed but I have not found one yet.
Please get back to me with your results. Thanks
Jun 20, 2010 | Mtd 22" Yard Machine Push Mower
Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Jun 30, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
73 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
