Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
How to change oil on 158cc briggs - Yard Machines 158cc Push Lawn Mower #11a 034f200
  • 34 Answers
Bottom of mower...need a 3/8 in. rachet end ----goes insede the square screw.---be sure to have a 16-20 oz. low sided container to put it in......let it drip clean out ---about 15 min.
Posted on Jun 11, 2014
  • Yard Machines Master
  • 14,405 Answers
Remove oil check stick,Tilt it over and let it run out of the hole. New tech,lol.
Posted on Oct 28, 2012
2 Suggested Answers
  • 111 Answers
SOURCE: my briggs and stratton 158cc
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
Posted on May 10, 2011
What kind of oil do you put in briggs and stratton lawn mower 450
generally, all B&S engines use SAE30 oil, however your local temperature range may make this an unwise choice. Google B&S Oil Chart
Jun 17, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Briggs stratton
Firstly try changing the spark plug. If it still persists check the oil level. It may have too much in it.
Jul 14, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
How to drain oil from briggs & stratton 5.00 158cc engine
underneath the deck there is a plug, sit mower on bricks/wood and pull plug and use a bucket to catch old oil. Tim
May 22, 2011 | Garden
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
633 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
