Question about Dryers
Hot point dryer drum does not turn, but the dryer will heat?
The clothes do not tumble, switch works, and timer, makes heat
  • Dryers Master
  • 8,220 Answers
That might be bad glides on the front. Newer models have glides on top of the drum while older models have glides on the bottom. Both are easily replaceable. The belt might be broken because of the glides.
Not all hotpoint dryers are built the same but I made a few videos of these dryers to give an idea how to get into them:
More from my blog: Hotpoint dryer repair
Posted on Oct 26, 2012
the dr
  • 447 Answers
SOURCE: No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Posted on Oct 03, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: Dryer drum won't spin/tumble clothes
Chances are it's a broken belt. If you hear the sound of the motor running and your dryer is heating, there's nothing else but the belt.
Changing the belt yourself is pretty easy if you can use a screwdriver and have a little mechanical ability. The new belt is around $20, and you'll save big if you don't call a service person to do it for you. A good site with a step-by-step illustrated procedure for changing the belt is here. They also sell parts, or you can find the belt locally at any appliance parts store.
Posted on May 04, 2009
jsrock516
  • 5911 Answers
SOURCE: dryer
There's only a couple of things that will cause the problem you just described. A broken dryer belt, or a defective drive motor. However, most drive motors are equipped with a centrifugal switch that closes when the motor turns. Without this switch closed, the heating circuits would not energize. So...I would recommend you check to see if your dryer belt has broken. If you can post back with comments on BRAND name and MODEL number (located along the inside of the door opening somewhere, or on the back of the console) I can give you advice on how to repair this yourself. Let me know. I hope this helps you.
Posted on Nov 12, 2007
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
futureloginn
  • 734 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Timer knob not turning and its not heating up
If you are setting the knob to begin a cycle AND the drum turns when you start it AND the timer knob does not advance, the timer is likely defective.
Some dryers with truly automatic cycles (using moisture or temperature sensors) will not advance the timer if there is a no-heat condition due to a bad thermostat or heating element. This would show as the dryer tumbling a load forever and the clothes are cold and wet when checked.
If the dryer will not do anything at all AND the timer knob does not advance, check the power (circuit breaker/fuse), then the dryer door switch. When the door switch is defective or the door isn't fully closing, it stops everything, period. There is a thermal fuse on some machines that will also cause this problem.
Good luck from Detroit, MI.
Oct 19, 2011 | Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Tumbler is making wierd sound but the drum still turns and it gets hot
drum rollers/glides, may be the idler pulley:
ttp://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Miele T8005 Tumble Dryer
Dryer makes noise that sounds like tumbling glass and smells hot
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 19, 2010 | GE DBSR453EBWW Electric Dryer
Once we put a load of wet clothes in the dryer after about 3 minutes the dryer shuts off. The top of the dryer becomes extremely hot. We open the dryer door and let it cool down and then the dryer starts...
Wet clothing doesn't allow proper ventilation while tumbling clothes. This in turn causes electrical shorts: steam in chamber and reduces airflow. Reduced airflow will will cause the drier to shut off on an over temperature condition. Moral of story, spin clothes as dry as you can and when tumbling, make sure you have good ventilation to get best results.
Sep 26, 2009 | Dryers
Dryers Logo
104 people viewed this question
Top Dryers Experts
