Question about Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive
I want driver Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive
  • 5 Answers
SOURCE: can't access or play games on my toshiba external hard drive
What does it say when you run it?
Posted on Jun 08, 2009
  • 2666 Answers
SOURCE: unlock a toshiba hard drive 20 gb hard drive code
Just reformat it.
Posted on Dec 21, 2009
jepito
  • 216 Answers
SOURCE: Toshiba (MK1031GAS) 100 GB Hard Drive - Cant be viewed in My comp
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Posted on Dec 24, 2009
  • 75 Answers
SOURCE: compatible hard drive to replace a Toshiba MK8025GAS 80 GB
You can buy hard disk for your model from following link at low price
http://www.laptoppartsexpert.com/c-47805-sony-vaio-vgn-vgn-s-series-vgn-s170p.html
Posted on Jul 21, 2010
  • 1768 Answers
SOURCE: i can't find for toshiba
Please provide more information as to you issue such as :
1.Have checked the user manual 1st?
2. Did receive any errors when connecting the drive?
3. if this is an internal drive > did you check to see if you have the cable installed correctly> that is is pin 1 connected > is the data cable properly installed.?
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help
determine the resolution and guide you to the proper fix for your issue.
Thank you.
Posted on Mar 18, 2011
My toshiba mk 8026gax needs repaired?
Try right clicking My Computer > Properties > Tools > Error Checking > Check Now > place checks in both boxes and Start. Run when not in use. This may take some time run. Plus OS partition will require a reboot to be checked before Windows starts. Hope this does it and not the other.
Aug 29, 2012 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Toshiba MK8026GAX drive no longer boots win7 pro. I tried to use a USB to SATA/IDE Cable, but it doesn't get recognized. It looks like 44 pins don't connect to anything, is this the power...
Normally with ide to usb cable it should connect to the 44 pins and provide power at the same time. Make sure you are connecting it correctly. Do you hear it spin up at all?
Jun 22, 2012 | Toshiba Computers & Internet
I want to use Toshiba HDD2191 took from old laptop and put as USB box for an external Hard disk, but window vista can't recognize it, shall I search and download disk's driver? tks
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Jun 07, 2011 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
I can't find for toshiba hard drive MK8026GAX
Thank you.
Mar 16, 2011 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
I need drivers toshiba hdd2191
Hard drives don't need drivers. All you do is simply plug it in and boot up the system.When you get to the desktop your PC should automatically detect the new drive and configure it for you. You should find it under My Computer.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 01, 2010 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Recomended replacement HDD for HP Compaq NC6120 (PG825EA#B1A). Original HDD "Toshiba MK8026GAX"
Circuit City currently haas some really great deals on the hitachi 500GB 7200/16 MB 2.5 Mobile Sata HD for approx $90 with no shipping fee. Simply to install and works like a charm. I have replaced about 6 of the original Toshiba hard drives in the past few months and not had a single complaint only complimentary feed back about the Hitachi replacements. Its worth looking into.
Item # H450-9100 BM
Feb 07, 2010 | HP Compaq nc6120 Notebook
Toshiba REGZA 37AV555D smashed screen
Yes the screens can be replaced and if you're half decent with a screw driver (and have the patience of a monk) it's probably worth attempting yourself.
Ball park figure for a new screen is around £150 but I recommend you get on eBay and buy either a used screen or smashed up laptop and take the screen off that. It should work out a much cheaper repair.
Dec 15, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
THE SCREEN ON MY LAP TOP IS DANCING
It's probably a virus. Try doing an emergency scan. If you have Nortan AntiVirus it'll be easier. So try doing that and I hope it helps...
Good luck
Aug 06, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Hard drive is not recognize by the computer
Both XP and Vista have this feature that requires that new installs of hardware be certified by Microsoft within anywhere from 30 to 60 days from installation.
Run an install (not a clean install which will wipe your data, mind you, but an install accomplished by installation disks, where you will be asked which kind of install you wish to accomplish, and you will be asked to register your software using your product key)
If you need additional information, I will be more than happy to assist you.
Apr 07, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Drivers
hi..there...maybe you mean the update firmware for your hard disk... but i think only the expart can update the firmware of hard disk 'cause it high risk and can make your hard disk doesn't work anymore.
so same like other if your hard disk works normally it doesn't any driver at all even you us XP or Vista operating system....
Feb 02, 2009 | Toshiba (HDD2D15) 80 GB Hard Drive
Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
