Question about Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune Dryer is not dring good, it takes forver to get a load done, I am sure it is a sensor, any ideas?
  • 1 more comment
  • wile13 Jan 03, 2009
    The vent and the dryer and tube were all cleaned, still not heating well, the MODEL # is MDE4000AYW.
    Does it make a difference if it is on timed or sensor?
  • ckhenthorn Jan 03, 2009
    I am having the same problem. My husband and I cleaned out the vent and it is still not working. I also think it is a sensor. The time dry works, but the sensor drive doesn't.
  • hootsie Jan 13, 2009
    The dryer is taking twice as long to dry as usual. It does not seem to make any difference whether on sensor dry or timed dry. There seems to be heat. The lint filter and exhaust tubing are clear. Might this be a sensor problem? What function does the limit switch perform?
  • 115 Answers
First off you need to turn on your dryer and go outside and see how much airflow if it is not standing the damper all the way open you got a stopped up vent and that is why it is not drying
Posted on Jan 03, 2009
  • Steven Carter Jan 03, 2009
    yes try it on timed and see if it does better that cuts the moisture sensor off
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Jul 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune Model #MDG6800Aww
Hi!! You seem to have a problem with your heating element on the dryer..Also make sure that your breaker going into your dryer is on..Good luck..
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer
the wire my be off the sensor , but when you say it worked after cleaning vent makes me think the vent needs more cleaning, the dryer is designed to run until the clothes are dry if that takes 4 days it will run 4 days, if the vent is not good it cant dry, remove the vent and run a load see what happens with out any vent on it
Apr 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
203 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
