Question about Creative Labs Zen Touch MP3 Player
No music library content
When last turning on my Creative Zen the screen displayed an 're-constructing library' icon. There is no music in the music library, and no artists or albums displayed. The settings still show 10G as being used on the player. When connecting up to the computer, the computer listed the player library as being empty also- and when attempting to transfer music to the player it failed. I have reset the player several times, but with no results. Any ideas? Help!
  • gobie Dec 02, 2007
    By mistake,I pulled my Phillips Go Gear player off its connector while connected to my computer, and now it shows the lists to be empty but still using the space.
    Can you please help?
    President:
  • 4,402 Answers
Try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Posted on Jan 28, 2008
I have a Creative Zen Sleek (20G) andit will not reboot as it comes up with "Hard disk problem" Could you let me know how to get this repaired
this is a recovery for the zen player
Detach your ZEN 20GB from the PC and ensure that it is turned off.
  1. Connect the power supply to the player (Optional).
  2. Slide the Power switch towards the Power On icon zen_20gb_reset2.jpg and hold it there while inserting one end of a paper clip into the Reset hole underneath the player. zen_20gb_reset1.jpg Warning: Take care to insert the paper clip into the Reset hole and NOT the Microphone
  3. The Rescue Mode screen appears when ZEN turns on.
    1. Remove the paper clip and release the power button.
    2. The following options will be displayed:
    1. Clean Up
    Scans the player and removes invalid links from its music library.
    Does not affect music files themselves.
    Format (All) Caution! Erases all content!
    Save a copy of your player's content before formatting.
    Reload OS/ Firmware Caution! Erases your player's firmware.
    DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
    Reboot Reboots the device.
  • Aug 20, 2008 | Audio Players & Recorders
    Creative Labs ZEN Vision:M
    Check if there is an option UPDATING LIBRARY to update library.
    Oct 30, 2007 | Creative Labs ZEN Vision:M Digital Media...
    Why zen sleek photo won't download music
    i have a zen sleek and every time i turn it on it says rebuilding library. It completes this but deletes the last album etc that i put onto it. back down to the last album i put on before it started doign it. So i cant put anymore mousic on becuase it deletes it..Any Help?
    Apr 17, 2008 | Creative Labs Zen Sleek Photo MP3 Player
    Zen Vision M
    If you reset it and it goes back to just the zen screen, then I had this problem once too. You need to go to recovery mode (which is still possible).
    1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
      If the battery is too low, charge the battery fully before continuing
    2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
    3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole,
    press gently and remove.
    It will display the following options.
    Clean Up
    Reboot Reboots the device.Here's the link to the site where I got the info from. (it's another forum). Good luck!
    http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=151527#M151527
    Jan 26, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Freezing
    Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
    This is from Creative's website:
    Zen V Plus and Zen V
    1. Detach your player from the PC if it is connected, and turn off the player.
    If the player stops responding, you can reset the player. To reset the player, gently
    insert a thin object into the Reset hole located below the power switch.
    2. Press and hold the Play button while powering on your player.
    3. When the player displays the Creative logo, release the Play button.
    It will display the following options:
    Clean Up
    Message Edited by Jason-CL on 09-11-2006 12:02 PM
    Forum Administrator
    Creative Labs
    Jan 06, 2008 | Creative Labs ZEN V Plus MP3 Player
    My creative zen v plus is not detected by my pc when connected its screen has reddish lines neither it is shutting down nor it is working
    Clean Up
    Forum Administrator
    Creative Labs
    Jan 05, 2008 | Creative Labs ZEN V Plus MP3 Player
    Help
    Clean Up
    Format (All)
    Reload OS/ Firmware
    Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
    Recovery Mode
  • Detach your player from the PC if it is connected, and turn off the player.
  • If the player stops responding, you can reset the player. To reset the player, gently insert a thin object into the Reset hole located below the power switch.
  • Press and hold the Play button while powering on your player.
  • When the player displays the Creative logo, release the Play button.
  • It will display the following options:
    Clean Up Scans the player and removes invalid links from its music library.
    Dec 06, 2007 | Creative Labs Zen V MP3 Player
    Zen frozen on one screen even after I've restarted it.
    hard drive sounds bad. has it been dropped?
    try to do a cleanup
    1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
    2. Connect the power supply to the player.
    3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
    underneath your player, beside the data/power connector. Keep on holding the
    Play/Pause button while you release the Reset button. The Rescue Mode screen will
    then appear.
    4. After the recovery mode has started, release the Play/Pause button
    Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
    Zen Microphoto frozen..
    Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
    Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
    Creative Labs Zen Touch MP3 Player Logo
    66 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Mohamed Ismail
    Mohamed Ismail
    Marvin
    Marvin
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
