Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
My mayage centennial washer is not agitating draining or spinning
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: centennial washer, will fill with water, wont spin
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Posted on Apr 30, 2011
SOURCE: My mayage centennial washer is agitating before
We had the same problem with our Maytag Centenial Washer. I simply removed the Auto Fill Sensor, cleaned the contacts with Deoxit contact cleaner and problem solved. All was done in less than 20 minutes.
Posted on Nov 14, 2011
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Nov 29, 2013 | Maytag Centennial Series MVWC200XW
Maytag Centennial Agitator wont spin
what is your model number is then we can get started then
Jan 17, 2013 | Maytag Washing Machines
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My mayage centennial washer is agitating before the water begins to come in , how do I fix it?/
Oct 14, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
