Question about E&B Giftware E and B Giftware Whistle-and-Find Remote Control Locator 3 pk
Park Avenue Golf Ball Monogram Stamper Does Not Work
The letters do not touch the ink tray, so no ink is transferred to the golf ball.
  • Rick McCallum
    Rick McCallum Aug 26, 2012
    the letters must go in upside down with the last letter going toward the hinge then you place the ink ribbon ontop of the letters and firmly squeeze the handle "At least that is how mine works then there will be a bit of excessive ink on the ball that wipes off easily ten you brush on the lacquer to keep the ink in!
Your ball is on the green hit by another ballwhat is the procedure and what rule
Scenario 2: Both Balls on Putting Green
"Both balls on putting green" means on the putting green prior to the stroke in question.
The ruling here is covered in Rule 19-5a.
From the green, Player A hits his putt, but the ball strikes the ball of Player B, who was also on the green. In match play there is no penalty. In stroke play, it's a 2-stroke penalty to the player whose ball was in motion when the balls collided.
Repeat: It's not a penalty against the player whose ball was at rest; the penalty is against the player who struck the putt.
Ads The player whose ball was at rest replaces it to its original position; the player whose ball was in motion plays it as it lies.
Return to Golf Rules FAQ index
Oct 27, 2015 | Golf
If you declare a ball lost and return to the tee but you ball is found before you make another stroke, can you play the original ball?
I don't think so. However, it might depend on what type of competition you're playing. Otherwise once it's been declared "lost" then you're obliged to play another ball and take the stroke and distance penalty. You can pick the "lost" ball up for later use.
Also check out R&A rules of golf : The Official Website of The Golf governing body
Sep 22, 2015 | Cars & Trucks
In golf, when may I pick up and clean my ball
The ball may be lifted and cleaned
- when in play on the green, but not when another ball is in motion, and must be marked
- elsewhere on the course when in play and lifted for a reason prescribed under the rules, but not when determining its fitness for play, determining whose ball it is, or repositioning the ball to avoid interference with another player
Failure to observe these rules is a 1 stroke penalty
Sep 07, 2014 | Golf
Can a golf ball be replace by a different type of ball during tournement play
"There is nothing in the Rules of Golf that prevents a golfer from switching to a different brand of golf ball (i.e., from a Titleist to a Bridgestone) on every hole on the course - so long as the change is made between the play of holes.
However, there is something in the Rules of Golf that says a tournament committee can impose such a rule.
It's called the "one ball condition" (in the rulebook, it's in Appendix 1, Part C), more commonly known as the "one ball rule." As you probably know, all Tour events are played under the "one ball rule." And any rules committee may adopt the "one ball rule" for its competitions.
"The "one ball condition" requires the player to use the exact same brand and type of ball throughout the round. For example, if you tee off the first hole with a Titleist Pro V1x, then that's what you must play throughout the round. You may not switch to any other brand of ball, nor even to any other type of Titleist ball. You started with the Pro V1x, so the Pro V1x is what you must use on every stroke. "If the "one ball rule" is not in effect, however, golfers may swap out different types of golf balls at any point in a round of golf, so long as the change is made between holes rather than during the play of a hole."
Aug 25, 2014 | Golf
My son threw a golf ball at our Sanyo LCD - 42" -
I assume you meant the screen is now broken.
Some things to consider:
1. Replace the son with one who does not throw golf balls in the house. Ha ha! [jk]
2. Check to see if the warranty (usually online if you don't have the original paperwork) covers screen breakage, or ask the store where you bought the tv if there is anything they can do.
3. If the warranty is a no-go, contact the tv manufacturer and see why they may do... what the cost would be to repair etc. Some screens are covered in case they crack, but it is probably obvious it wasn't a manufacturer's defect if a golf ball hit it.
4. If those steps don't work out, check videos or info online to see if this is a job you or a techie could do - (in last case scenario).
5. If none of these check out, sadly, you might be left with a very large, expensive doorstop.
Good luck.
Sep 23, 2012 | Televison & Video
Blinkers on my 84 fifth ave new yorker don't work
its a silver fuse under the dash about the size of a golf ball
Dec 09, 2008 | 1986 Chrysler Fifth Avenue
E&B Giftware E and B Giftware Whistle-and-Find Remote Control Locator 3 pk Logo
473 people viewed this question
Top E&B Giftware Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an E&B Giftware Toy Expert? Answer questions, earn points and help others
