52 Inch RCA D52W17 BYX1 projection screen tv cuts off when i TURN ON
Turn power button on and screen remains blacks and cuts off in a few seconds. When you try to turn it back on, we have to wait a couple of minutes before we are able to turn it back on.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The set literally has a 3 strikes and you are out where it will try three times and go to shutdown.
The common issues this set has are bad solder connections under and around the high voltage transformer and also in some cases the High voltage splitter block (located way up front behind lower grill below screen unit and behind a removable inspection plate).
The transformer rarely fails but can--photo of what is general appearance of this type of part is attached.
52 Inch RCA D52W17 BYX1 projection screen tv cuts  - 10_26_2012_7_48_25_pm.jpg
Posted on Oct 26, 2012
SOURCE: RCA 52 inch TV
My tv will not turn on the light comes on three times then stops till I try it again.
Posted on Nov 11, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
Posted on May 11, 2009
hotratchet
  • 952 Answers
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Posted on Jun 19, 2009
nicknovikov
  • 100 Answers
SOURCE: RCA D52W19B 52
check hor.out.transistor,HV cap,dempfer diode.good luck.
Posted on Feb 07, 2010
I have a 52" rca model D52W17. I turn it on and about 10-15 minutes later it just cuts off. Sometimes it trys to cut back on and then goes right back off. I smell nothing burning, screen looks fine when on...
without takeing mesurment i would be makeing a guess = there are some capacitors that could be going bad.. intermetant or delayed shutdown ussally means a overheating or failing component or bad solder connections.
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not start properly RCA D52W17
Replace CP150 , CP120 and CP114 that should take care of the Issue of hard to power up. You can get the replacement capacitors at the following link with free instructions.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
Tv loses power
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w17 hdvt rear projection Problem
If the light cycles on three time the micro is working but there is something shuting it down.a This is not clear cut it would need to be troubleshot. You need to call a tech.
                                   Packman
Oct 29, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
