Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna mod 41 chain saw wont start
I have put in a new plug & sprayed the wires to dry thrm out & it started 3 days later I went to start it agin & nothing . What is wrong ? Also I have no spark.
  • 17 Answers
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Posted on Jan 03, 2009
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
No spark when trying to start
If there is no spark with a new plug and the earth cut out wire diss connected from the ignition switch, then it will require a new ignition unit part no. 530039143 ( if it is a Husqy 36/41 )
Feb 26, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My 435 Husqvarna chain saw runs great but on hot summer days when I turn it off and go to restart it 10 min later it will not start. had the same problem with it last summer and took it into the local...
The carburettor is getting too hot and fuel is being blocked from feeding into the engine. Make sure that the carburettor is clean and has adequate cooling while the engine is running. If you still have problems withs starting, blow the carburettor cool or use a damp cloth to cool it if starting is a problem.
Jul 13, 2011 | Husqvarna Chain Saw 20" Bar
I have husquavarna chain saw s/n 95212H01984 with sticker that says 41 Air Injection. Need to buy chain and/or chain bar. Need to know the model number for this serial number. Can you provide
The saw is a 41, as standard it ran a 15" bar and chain, in the UK it ran a .325 pitch, however in the US, it ran a 3/8 pitch chain, as you should change the sprocket if fitting a new chain, i would put it on .325 if it is not already, the sprocket is part no. 530069342, the 15" chain is 501840664, and the guide bar is 508926164 these are .325 pitch 050 gauge and 64 drive links, this combination will cut much faster than the 3/8 low profile combination.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 137 chain saw - put a new plug in and won't start run if you put a small amount of gas in plugfor just a second or so made sure gas line is not stopped up from tank to carb. less than 2 yrs...
Sounds like the diaphragms in the carburetor have gotten dry and won't flex anymore. Install a new kit in the carb and recalibrate the screws. You should be good to go.
Nov 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't start my Chain Saw Husqvarna 350.
The fuel may have been replaced, but is the fuel filter clean or is the fuel line cracked? Even though you cleaned the spark plug, did you check to see if it has a spark? If not, maybe a new spark plug or check the wire to make sure there is nothing blocking where the wire and spark plug connect. Is the air filter clean? Just a few more things to check out...
May 14, 2010 | Husqvarna Chain Saw 20" Bar
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Jan 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
652 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
