Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter thermostat Manual model# 44860 - Hunter Fan Company 5/1/1 Programmable Thermostat
SOURCE: hunter thermostat 44860
How do I set the air conditioning? I'm lost on this thing and I can't find my manual. Apparently the one I saved is in Spanish. Please help, it's getting warm here in Ohio.....and I have horrible asthma.
Posted on Apr 25, 2008
SOURCE: Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Posted on Jan 02, 2009
SOURCE: heat won't come on, but
Look at your igniter on the furnace.
Posted on Jan 05, 2009
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44002.pdf
Posted on Jan 09, 2009
  • 205 Answers
SOURCE: Need a user guide/owners manual for a hunter
Most manufactures have all their manuals available (for free) online, if you have trouble finding their site, try google or your fav search, good luck, Chuck
Posted on Mar 16, 2009
Air handler fan runs continuosly. Will not shut off.
There should be fan options "automatic" which will turn on with heat or cool. , continuous, and perhaps "circulate" which is a randomized turn and off. Double-check your Thermostat programming manual. If no manual,
Try this: http://www.manualslib.com/
Mar 04, 2015 | Hunter Universal Touchscreen Thermostat...
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Hunter 44860 Thermostat - continually resets clock to 1am
My Hunter 44860 is doing this also. It started on Nov. 1, 2009. It also displays the day of the week as "SUNDAYAY" when it hangs. I believe this is a firmware problem with older stock. Unfortunately I bought it from Lowes this fall and lost the receipt. I am going to try to return it to Hunter Fan Co for an exchange.
Nov 09, 2009 | Heating & Cooling
Hunter 44860 touch screen temperature override
"Hunter" says it all. Throw it out and buy a honeywell, robertshaw, or a white-rodgers. Hunter stats are notorious in the business as being problematic.
Oct 07, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
206 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
