Question about Toshiba Satellite L855D-S5220 Laptop
My laptop wont start
Last night i went to bed and it worked i woke up today and it will not turn on, it will not show that is is charging. i also checked the battery and charger and they work on my sisters laptop. there is no response from my laptop at all it has not bin hit or fell to the ground. please help me
    Novelist:
    Champion:
  • 233 Answers
If you are sure that your charger and battery are working as usual. The possible cause is the laptop lid switch.
If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your screen when your lid is open or closed respectively.Normally the operator does not push this button. These are fragile and broken easily on some laptop models. Sometimes these can be fixed,more often they will require replacements. If you aren't an expert repair person, get a technician to repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to repair than desktops. It may be worth it to spend the money for repair.
Posted on Oct 26, 2012
  • 38 Answers
SOURCE: Toshiba Laptop wont work unless plugged in.
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
Posted on May 13, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Dell laptop charger
First try starting the machine without the battery, only the charger, Then check the charger with an ohm meter to see if it's working properly. The out put readings are listed on the charger. In case of a surge, the charger is designed to go out first before damaging the system. However, this is not always the case. If the charger checks good, then you should take it in for a professional diagnostic because the problem may be with the power management system on the motherboard. One thing to keep in mind for future reference is when moving to a different location with your laptop, when unplugging the charger, always unplug the charger from the laptop before unplugging from the wall socket, and when plugging in, always plug the charger into the wall socket before plugging into the laptop. This will keep from surging your system.
Posted on Jul 16, 2008
RescueTechLA
  • 2653 Answers
SOURCE: Toshiba Satellite A135-S4527 Charger problem
Get another laptop.
The A135 is a lemon.
Problem is either with the dc jack on the board or more than likely the motherboard is damaged.
I've repaired a number of A135's and 95% of the time motherboard had to be replaced.
Sorry for the bad news, but I hope this helps.
Posted on Mar 02, 2009
SOURCE: my toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Posted on May 19, 2009
  • 157 Answers
SOURCE: my laptop won't turn on
remove the battery and power cord for a few minutes then try again. if that doesnt work, remove the ram and put it back in. there is a good chance you friend something. do you have the power ratings of the aftermarket charger you tried? and did it turn on at all with the aftermarket one?
Posted on Jun 16, 2009
The tv shows it turned on the green light is on, but there is no picture, when we went to bed last night it was working and when we woke up to turn on this is what happened
First check all the cables make sure they are plugged in Second make sure the input is set to tv or whatever input goes to your cable box
Feb 28, 2011 | Maxent Televison & Video
It won't turn on. It worked last night and I plugged it in before I went to bed, and when I woke up it was black. It won't turn on now or make any type of sound.
battery could be gone..also you could check wire connections to battery. Even better measure if the battery has a charge with a voltmeter.
Jun 13, 2010 | Samsung Behold Cell Phone
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
Went to bed last night with heat woke up today everything house was cold, looked at thermastat it said 63degrees,, checked out furnace it starts up but doesnt ignite, sounds like its in the start up stage...
Does the hot surface igniter glow? If not, it is probably cracked. If this is
a 90% furnace, it could be that yuor intake air is causing the problem.
Dec 27, 2009 | Goodman GMS90703BXA Heater
Phone won't charge or turn on
Try removing the battery and clean the contact's, then reinsert the battery and let it charge, if it do'es not begin to charge your adapter may need to be replaced, or your battery.
Apr 06, 2009 | Lands Phones
The battery might not just hold any charge. If you have had this phone for less than a year. I would try to get a replacement from the carrier.
Jan 22, 2009 | LG Shine 720 Cellular Phone
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Toshiba Satellite L855D-S5220 Laptop Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
