Question about Garden
How to remove head of troy bilt af720 aero flex head on troy bilt gas trimmer
How do you remove the head from the af720 aero flex troy bilt gas trimmer.
slohry
  • 87 Answers
SOURCE: where is the gas filter located on a troy bilt trimmer?
The fuel filter is inside the fuel tank. Replace the fuel filter. Do not clean it.
Posted on Apr 12, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 1114 Answers
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Posted on Jun 21, 2009
wadembly
  • 475 Answers
SOURCE: How do you disasemble the head on the 4 cycle gas
the head is bolted down by 4 torque bit screws some people call them star wrenches from the top but all plastic & carb needs to be removed more less everything to get to the bolts around the cylinder head as well as crankcase but to be honest its cheaper to buy a new one then repair it i had one repaired it & by the time i replaced everything i could have bought a new one cheaper then the parts cost me
Posted on Jul 09, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt 25cc head won't spin?
I have run onto several of the Troy-Bilt with this trouble. Seams the part of the head where the flex drive shaft fits into is weak and gives up. Unfortunately this part of the shaft housing isn't serviceable and the shaft will have to be replaced.
Aug 25, 2014 | Troy Garden
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Can you interchange the curved shaft with a stright shaft for string trimming
Most of the curved shaft models have the EZ link removable coupling system allowing you to use different accesories on the machine. A straight shaft model, however is not removable and the flex drive is of one piece and one length.
Apr 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
My troy bilt tb70ss trimmer sounds like something is stripped the motor will wind out but the head wont move its only 1 1/2 years old
will need to check if any debris is wrapped around head jamming the head --or -flex shaft is jammed or damaged separate shaft from motor and will see in shaft the flex shaft that turns the head try turning head by hand and observe flex shaft if binding or broke need to lube or replace
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weedeater Head won't Turn?
I had the same problem with a Troy Bilt tb65ss. It sat in my garage for a year until I decided to tear it apart. I pulled of the head, removed the debris shield with a Phillips screwdriver, then removed the upper head assembly from the shaft. The inner flex cable is shaped like a square and had wiggled up the shaft until it was no longer engaging. I pulled it down and reassembled the upper head assembly with it engaged. It was a simple fix and took less than 10 minutes. It looks like a terrible design and a repeat problem. If it happens to me again I'll probably jb weld the flex cable in place. Good luck! You can always call the manufacturer and haggle over warranty and haul your trimmer all over town to an authorized dealer who will put it at the back of their pile because you didn't buy it from them or you can fix it in 10 minutes!
Sep 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
How do you disasemble the head on the 4 cycle gas troy bilt trimmer
Jul 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
