Question about Dryers
Unable to make heater box flush or snug with air duct assembly
I have a Kenmore Elite H3 dryer (model 110.82822102). I have replaced the heating element but am having difficulty putting the heater box (part 46, which houses the element) into the Air Duct Assembly (part 5). There is a metallic protrusion at the back of the heater box which will prevent it from going directly into he circular hole of the Air Duct Assembly. So I have been trying to go at an angle so the metal part goes in the hole first, then I try to turn the heater box so it will be snug with the air duct assembly. But it is not working - is there any trick to get the heater box snug with the air duct assembly? Much Thanks.
4 Suggested Answers
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
Jahn27
  • 1554 Answers
SOURCE: having trouble getting the heating
Refer to the following pictures:
Indicate the exact model number of the machine for further advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 05, 2010
danoyachtcap
  • 2899 Answers
SOURCE: Kenmore Dryer Mod: 110
Thanks for using FixYa.
Most of those Kenmore dryers require a standard or phillips type screwdriver.
The volt meter should be a voltohm meter so you can measure the AC voltage to the heater & also the resistance to test for heater element open circuits.
Hope this will help you
Posted on Jun 28, 2011
My Kenmore Elite H3 dryer check the lint screen comes on when I try to dry my clothes but the dryer does not produce any heat help me
You should check for continuity on the heating element. If you have continuity there, be sure you have voltage to the element. You have 2 (I beleive) temp sensors in line also. Check them, one may have a reset button (not sure). Make sure your exaust duct is clear to prevent thermo sensor burn out in the future.
May 16, 2011 | Kenmore 82822 Electric Dryer
73952 / 73954 / 73956 Gas Dryer: my kenmore elite HE5 110.8772 is not heating. My...
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore 73952 Gas Dryer
I installed a new kenmore elite oasis elec dryer...turns on but no light,no heat. any ideas? thanks!
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Apr 08, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite smartheart HE4 dryer is tumbling but not drying clothes
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 dryer does not heat up
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Mar 09, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite Smartheat Quietpak 9 HE4 dryer taking longer to dry
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore elite oasis dryer does not get hot. It does spin though
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Jan 09, 2010 | Kenmore Elite Oasis ST 7806 Dryer
Kenmore dryer model 96273100 no heat.
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Based on the model number you provided, I'm assuming this dryer can be accessed by removing the back panel.
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
I hope this information is helpful to you. Post back if you have any further questions, or need assistance in finding replacement parts.
May 08, 2008 | Dryers
Kenmore Dryer Model # C85172
There is no fuse. If you have a no heat related problem any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Getting to the heating circuit to determine if the components are good or bad is the next step. Remove the lower kick panel under the door by removing the screws under the bottom edge of the panel. HINT: Placing a couple of blocks of wood under the front feet of the dryer will make this easier. With the screws removed, the panel should drop down then come off. If the panel sticks, a slight tap on either side should knock it free.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. All the heating components are located on the right-hand side under the drum. Resistance readings are as follows:
Thermal Cut-Out (TCO) (mounted to the heater box all the way at the rear.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Failure to do so can result in repeated failures.
I hope this information is helpful to you. Post back with comments if you have any further questions, or need assistnace locating parts.
Apr 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite electric dryer 11084832200
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry clothes properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door:
a. Remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side.
b. On models with no lower kick panel, lift the dryer top and remove the screws that hold the front panel in place.
c. The Kenmore Elite & Whirlpool Duet have a couple of screws under the bottom edge of the panel under the door that you need to remove.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
