Question about HP Deskjet D2360 InkJet Printer
Scanner not scanning
Hi, Hank here...we are having a problem trying scan from an HP F4180 deskjet...so far nothing happens when the button is pressed but the on/off button blinking...the doc is not scan???
  • hank_hankers Jan 03, 2009
    all in one
    HP F4180 not scanning
  • 300 Answers
Initially, I would suggest using the HP Printing Diagnostic Utility found here. Once you click that, you will see a Download Only button. If you need detailed installation instructions you will see a link below the Download Now that says View Directions which can be used to get step by step instructions for installation of the programs.
If that doesnt correct the issue, I would suggest removing and reinstalling the printer by following the directions below:
I would suggest that you disconnect the usb cable from the printer. Then, if the printer was previously installed, uninstall all programs related to the printer through Add/Remove Programs in the Control Panel.
After restarting the computer with the printer still disconnected you can follow the directions below to download the latest drivers.
To download the drivers you can go here. When the page opens you will need to choose your operating system. Then, from the Drivers section I would choose the full feature driver.
Once you click that, you will see a Install Now button that will allow you to immediately install the software and/or a Download Only button that will allow you to download the file for later installation.
Either option will have a link below them that says View Directions which can be used to get step by step instructions for installation of the drivers.
Hope this helps. Please rember to rate this information.
Thanks
Posted on Jan 08, 2009
The printer is on and working. However it is not scanning the color picture
Sometimes this happens when you have pressed the scan button on the printer, to no avail, and then try it on your computer..... Try disconnecting the printer from your computer, and powering down the printer, then reconnect printer, and restart it, and try scanning FROM THE COMPUTER.
Aug 04, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
My scanner will not work or my printing from the computer
In order for you to scan you need "HP Digital Imaging Monitor" to be running.
Jul 06, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I am trying to put a picture from my printer to my computer how do I do it.
To scan a picture into you computer, follow these steps below:
Follow the steps below to scan an image from the control panel:
1.
Lift the lid on the HP Desskjet F4180.
2.
Place the original on the glass with the side to be scanned facing the scanner glass and on the left front corner of the glass.
NOTE: For quality copies, ensure that the scanner glass is clean and that there are no foreign materials adhering to it.
3. Close the lid.
4. Press the Scan button located on the Printer. A preview image of the scan appears on the computer where it can be edited. The edits made apply to the current scan session only.
Make edits as desired to the preview image and click Accept .
NOTE: The Scan button does not work with the Windows 2000 operating system. The software CD contains drivers for Windows 2000 only and therefore has limited functions.
Cheers!
Apr 18, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Scanning
plz check in my computer is your scanner is visible, if yes then right click on the scanner and select scan and follow the on screen suggestions,
if your scanner is not visible in my computer then you have to install it with the cd which come along with the scanner
Dec 11, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F4180-no option to save as PDF
A simple solution to this problem is to scan to JPG as normal and then print the JPG to a PDF using one of the very good "print to PDF" utilities like the Cute PDF writer.
Good luck.
Aug 30, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet F4180 Scanning
ok..you may have blown drivers..go here, get new ones, and re install
Jun 16, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Scanning
hmmm...did you try this from the HP print manager on your computer?
that will help with deciding if it's a scanner issue, or maybe more like firmware.
www.hp.com
has that print manager.
Jun 01, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Hp deskjet f4180 all in one
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
Feb 15, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet D2360 InkJet Printer Logo
52 people viewed this question
Ben Johnson
