Question about Sewing Machines
Bernina 830 embroidery module maintance
The Bernina 830 embroidery module maintenance . The module squeaks as it moves. Like plastic on plastic, do I need to lube it.?
RickE1
  • 202 Answers
SOURCE: My machine Bernina 830 does not run.
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
Posted on Nov 29, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 180E Embroidery module not recognized
Anytime there is a communication issue between machine and module attach the module to a different machine and check it. Possibly at a dealership. This will tell you whether its the machine or module. If its the machine then the soldering points on the embroidery module plug to the A-print (on the side of the machine) circuitboard need to be checked. Then most likely replace the A-print circuitboard.
There are other tests that need to be done in the service program that will help pinpoint and troubleshoot issues with the embroidery unit. Such sensors or stepping motors, etc. Should be left to a tech.
Hope I helped.
Posted on Feb 11, 2009
  • 52 Answers
SOURCE: bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Bernina 830 stuck
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
SOURCE: DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
Posted on Feb 15, 2010
I would like to hear about other owners of the 880 and what problems they have had.
BERNINA 880 Review ' Sewing Insight
www.sewinginsight.com/bernina/bernina-880-review/ Mar 12, 2015 - A site visitor asked for a review of the BERNINA 880. ... Usually, machines that sew at speeds up to 1000 embroidery stitches per minute also come with considerably more ..... Beverly Rutherford Brother Innovis 950D Review ...
Sewing Machines >> Brother "The Dream Machine" or ...
sewing.patternreview.com > Forum > Sewing Machines Jan 13, 2015 - 10 posts - ‎9 authors Pattern Review ... Subject: Brother The Dream Machine or Bernina 880 Date: 1/12/15 ... Embroidery/Sewing Combo: Brother Dream machine.
Bernina 880 - Sewing Machines and Patterns Review
sewing.patternreview.com > Forum > Sewing Machines May 9, 2014 - 10 posts - ‎9 authors Bernina 830LE - Brother Dreamweaver VQ3000 - Bernina B530 - Janome ... I just read the manual a bit, then started tinkering and I had a ...
Customer Reviews: Bernina 830 Embroidery and Sewing ...
www.amazon.com/Bernina...Sewing-Machine/...reviews/B0081A3KMQ The 880 also has a stronger/different motor that can run at 1200 stitches per minute ... One is the way the camera works on some of the Brother machines, as well as ... I hope this review helps anyone wanting to buy any sewing machine really.
Bernina 880 - Sewing Machine Review - Top Ten Reviews
sewing-machine-review.toptenreviews.com > ... > Sewing Machine Review Search. Appliances » Other-Household » Sewing Machine Review » Bernina 880 ... Compare to the Top 3 Sewing Machine Review ... #2 Brother PC420PRW.
Best Sewing Machine - Bestcovery
www.bestcovery.com/best-sewing-machine-overall Apr 27, 2015 - Read our reviews to find the Best Sewing Machine and compare photos, specs and user reviews. ... The Bernina 880 Quilting and Embroidery Sewing Machine is ... The Brother XL2600I Sew Advance Sew Affordable 25-Stitch ...
Dec 27, 2015 | Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
I have Bernina 830 embroidery machine. I'm still a novice with this machine. An upper thread broke and could only be removed from the right side. I know that this is a NO NO but I had no choice. I r
Do you have a manual?
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Bernina+830+manual&_sop=15
You may need some cleaning, oiling or maintenance?
Tips for cleaning and maintenance:
Oil the hook after having used the content of 3 to 4 bobbins. The machine
screen will display a reminder
Increasing noise of the motor and/or irregular
stitch formation can also be an indication that oiling is necessary
Remove any lint from the hook and the bobbin area, then remove the stitch plate
See instruction manual chapter Maintenance/Cleaning
YouTube videos:
https://www.youtube.com/watch?v=mlBNy33bd3U
https://www.youtube.com/watch?v=mV4z3EAyMz4 Bernina 830 or 880 Thread Nesting Troubleshooting
Feb 08, 2015 | Bernina Sewing Machines
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
Is it possible for me to get a free download of the Bernina 830 instruction manual?
Are you talking about the 'new' 830 embroidery machine or the 'old' 830 Record mechanical machine ?
Nov 04, 2011 | Bernina Artista 180
Sewing Machines Logo
162 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
