Question about Daewoo KOG-867T Microwave Oven
Start stop button not work - Daewoo KOG-867T Microwave Oven
  • William Miller
    William Miller Oct 26, 2012
    We would need the full model number to help you.You can find links to helpful exploded view diagrams and part ordering help here.
    I recommend that you bookmark that link to your favorites.
    We're
    happy to help you with free
    advice and look forward to hearing from you.
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
I have an Emerson MW8168B 1100 watt Microwave. Start Button Problem.
the pads are touchy its probably been white knuckled too long
Apr 03, 2013 | Emerson MW8168B Microwave Oven
Can't unlock kennmore microwave, tried the start, stop/clear button it does not work
holding the stop / clear button for 5 seconds or the start button for 5 seconds usually works,
see this link
http://www.fixya.com/support/t8306273-unlock_digitals_butons
Feb 14, 2013 | Microwave Ovens
The stop and start buttons on my HMT t8656gb have stopped working. Can they be replaced or do I have to purchase a new one?
Good evening to you.
I hope the same thing is not happening to you that happened to me.
What happened was that I had the buttons had stopped working because of my impatience for the micro to work.
I thought I would give the micro a rest, disconnected the power and let the micro rest over night. Connected it then to the power and started it like i started it the way I did the first time.
I think it is worth the effort.
Kolbru
Apr 12, 2012 | Microwave Ovens
I cannot press start and stop button i think sensor is not working i can press rest 1234567 button n not 890 n start n stop button
Normally, it suggests the keypad is faulty. The fact that you have part function indicates the board is functioning. Replace keypad.
May 28, 2010 | Sanyo Microwave Ovens
Microwace buttons suddenly stopped working. Only
Your membrane keypad is failing.
Contact Danby Customer Service US / Canada
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
Jan 14, 2010 | Microwave Ovens
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Buttons dont work on danby microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn;t working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Daewoo KOG-867T Microwave Oven Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
