Model llr6144bq1
SOURCE: Whirlpool washer does not Spin fast
Is the drain hose blocked?
I had a wp washer and after moving into a new house we had a similar problem. I would come home from work drag the washer away from the wall, take it all apart and it would spin properly.
I'd button it all up and put it back in place and the next week she would complain again. When I was out of town she called the repair man. He came and cut 4" off the drain hose and the machine ran for another 10 years until the trany packed it in.
I guess the back pressure on the pump was restricting the transmission from spinning up to speed.
SOURCE: whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
SOURCE: My Whirlpool washer won't spin
Hi, It sounds like the coupler has broken. If the motor runs but doesn't do either of these things, here is how to
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Please let me know if this helps you or if I can assist you further.
Vic
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
