Question about Yamaha Tyros4 61-Key Arranger Workstation Keyboard
What are the best settings on a Tyros 3 to play Chariots of Fire
I want to add orchestral backing to song
Build the orchestral as a MIDI file and then merge your song and send back to the Tyros to perform it. Building on an external machine you will find is easier than trying to do it all on the Tyros.
Sep 15, 2011 | Yamaha Tyros4 61-Key Arranger Workstation...
Please help.both of my FC5 footswitches seem to have got screwed up with some registrations which I cannot seem to find on my Tyros 3 .I thought if I delete them I could get things back on track. At the...
In the Utilities screen there is the function that enables and disables as well as controls the polarity of the pedals. This is SEPARATE from the registration settings. The settings are in the "Controller" tab of the "Utility" menus.
Apr 14, 2011 | Yamaha Fc5 Sustain Footswitch
When i press down on it it wont sustain but when i take me foot off the pedal it will sustain. fc5 yamaha
You may be trying to use this with a Roland synth... they require the OPPOSITE type switch.
If you have a Yamaha higher end product such as Tyros, there is a setup screen in the utility menus to set the polarity of the sustain and other inputs and that setting may be wrong.
Jan 14, 2011 | Yamaha Fc5 Sustain Footswitch
My Tyros 2 plays additional notes when I play chords particularly in C, G and E-Flat scales. The challenge is that I am living in the Caribbean and there are nor official keyboard technicians nearby. I can...
This is not something that spare parts would likely be needed for.
The first thing to determine is if in the piano mode that the unit first comes up in do you get this problem. If you do not, the UNIT is likely OK electronically. If you DO get the problem as a plain piano at start up, then one or more disconnect diodes (small 1N4148) are probably shorted. This is VERY uncommon occurence. These diodes are on the contact boards of the keys themselves. Contamination of metal such as a paper clip or metal shard could cause the same thing.
The Tyros II has MANY features and a lot of these create layers that fire other notes when using styles as part of the stylle rhythm.
The keyboard split features that allow the keyboard to act as three seperate ones can lead one to think there is a problem.
I have two Tyros I and one Tyros II and have worked on all of them as they were purchased as damaged and non-functioning. I have schematics on CD and those are available from Yamaha America parts dept in California. They are copyrighted but they will sell you the CD with schematics, etc. for about $15.
I can help you troubleshoot the problem if it really is a problem. The first thing is to see if problem exists in the piano mode at startup. If it does, then try each note in combination to establish a pattern. If a disconnect diode is shorted, you will find certain notes interact. You need to find which are OK and which causes problems... Defining the keys as problems in chords does not help as we need key numbers such as C3 or F#4. Do the searches ONLY using two keys at a time as a matrix problem cannot be diagnosed doing three at a time or more.
Aug 01, 2010 | Music
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
Looking for music stand that fits on top of p120
These are sold online at Kraft Music
Yamaha WB53080R Music Rest
Replacement Music Rest for P120, P140, P155, PF500, PF1000
Jun 24, 2010 | Yamaha Music
My tyros 2 has fallen down very bad.now the left bass octave is off pitch(half note Higher) when i play the keybord with the accompaniaments.It works right ONLY when the ACMP is disambled what can i do....
Likely you have damaged the pitch bending wheel and offset it.
Try to pull it on pitch with the wheel... IF YOU CAN, then the alignment of the detent of the wheel has been disturbed and unit will need servicing... There are a lot of screws to open this and several very tender cables that can be damaged... I would recommend you take it to a shop experienced on this keyboard.
May 16, 2010 | Yamaha Full-Size Keyboard
YAMAHA TYROS 3, THE SOUND WILL CUT OFF IN MID PLAYING. IF I TURN OFF KEYBD AND UNPLUG,THEN PRESS START BUTTON, (CLEARING MEMORY?), THEN PLUG BACK IN AND RESTART PROBLEM IS OVERCOME. SEEMS LIKE THIS PROBLEM...
I have Tyro I and II myself.
If somehow the registration is being bumped up or down during playing that would do it. VERIFY all the settings for the external pedal inputs regarding levels and function. Some of these can be set to do more than one thing. As a result, a pedal connected to the three jacks MIGHT be used for sustain and also triggering a step in registration number that is unwanted.
One needs to analyze the state of the unit when this happens...this should be possible UNLESS the whole thing including the data entry and display is freezing.
With the thousands of internal settings that are possible, it will be hard for us to give a definitive answer.
If you can afford to lose user created stuff, do a complete factory reset of the unit.
Apr 29, 2010 | Yamaha Music
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
How do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
Yamaha Tyros4 61-Key Arranger Workstation Keyboard Logo
20 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
