Question about Psi Sistema GT11 1400 PSI Pressure Washer
I have a Sistema 1750TSS and I need to replace the pump cover (covers the 3 pistons) due to a pin hole leak. Are there any replacement parts (Sistema or other manufacturers) that would have a comparable cover that would fit?
Drive pin does'nt retract
Reasons for driver not retracting./
Check band on the outer part of the cylinder missing or not in place. Pull out cylinder and look for series of holes. These holes should be covered with rubber band or oring. The band/oring should fit snuggly.
Driver slightly bent making it hard to push driver up. Push driver up with any tool that fits into the nose. Should move up rather easily. If hard, pull driver and check for damage or oring too tight/loose.
Too much air leaking past the nose due to worn lower bumper. Bumper should not have cracks or missing pieces. Some nailers use a second seal below the bumper made of metal or vinyl. If broken or missing, replace. Finally, piston will not retract of there is an obstruction in the headvalve exhaust port. Good luck
Dec 17, 2013 | Tools & Hardware - Others
Car wont stay running and i thought it was feul pump or fuel filter. i replaced both and it still wont run. it will crank sometimes but cuts right off like its not getting fuel, at least thats what i was...
not value cover gasket leak out around spark plug not to inside piston. but cut right off how hot? no water in oil? or filled up piston? maybe head crack. fuel pump pumping? crack line not went eng hot. ture key on look or someone look 10lb of pressure comeing out fast.water no. antifreeze yes.
Sep 24, 2011 | 1996 Saturn SC
I have a 2003 tiburon and I changed the rear rotors and pads but can't seem to get the caliper back on cause the lower guide pin doesn't slide like the upper one. I have never seen this before is...
YOU NEED TO COMPRESS THE CALIPER PISTON USING SPECIAL TOOL 09580 - 3400 OR YOU CAN USE A LARGE C CLAMP AND THE OLD BRAKE SHOE NEXT TO CALIPER PISTON.BE SURE TO SIPHON OUT 1/3 BRAKE FLUID OUT OF THE MASTER CYLINDER BEFORE COMPRESSING CALIPER PISTON BACK IN THE CALIPER BORE.WHEN YOU FINISH REPLACING REPLACING REAR BRAKE SHOES.MAKE SURE BRAKE MASTERCYLINDER RESERVOIR COVER BACK ON RESERVOIR BACK IN PLACE.THEN PUMP BRAKE PEDAL TO SEAT BRAKE SHOES AGAINST ROTORS AND UNTIL YOU GET FIRM SOLID BRAKES.THEN CHECK BRAKE FLUID LEVEL.DONT DRIVE CAR IF BRAKE PEDAL FEEL SOFT NOT FIRM.CHECK FOR LEAKING BRAKE HOSE OR LEAKING CALIPER PISTON SEAL.
May 08, 2011 | 2003 Hyundai Tiburon
Where are the timing marks and how do u time a 1998 Pontiac Sunfire gt? I was told there are two 14mm holes for the two upper gears and a mark for the lowers. I had a hard time getting them to line up but...
hi, all newish cars have places for locking the engine, camshaft, injection pump. the camshaft groove is under the roker cover at the back (this is a flat bar and go's across the two camshafts). the injection pump locking pin normally pushes in the injection pump spocket, the front timming cover will need to be removed. the crankshaft locking pin normally locks-up No. 1 piston there is a bolt that must be removed.this is best done with the spark plugs OUT. ALL THESE LOCKING PINS AND BARS MUST BE REMOVED AND REPLACE THE BOLT FOR No,1 PISTON. method to install locking pin on No. 1 piston bolt locking pin and turn engine BY HAND ONLY BECAUSE YOU WILL DAMAGE CRANKSHAFT AND DO NOT FORSE it any more. once the No. 1 piston is locked check the camshaft and place the BAR. next is the injection pump push the locking pin into the sprocket. remember to REMOVE ALL LOCKING PINS AND BAR AND REPLACE BOLT FOR No. 1. p. s. you can put your own marks but is NOT RECOMENDED. i hope this is useful gerry
Sep 08, 2010 | 1998 Pontiac Sunfire
Piston sticking wont release the brake properly where can i get a new piston and seals
If you drive a short distance and the wheel is locking up. You can release the pressure by opening up the bleeder valve on the wheel. This should allow you to drive back to your starting point before it locks up again. The problem in in the master cylinder on the handlebar. If you take off the cover. put a wad of lint free cloth in the reservoir to soak up fluid. Do not spill on paint or plastic parts, cover bike with plastic. You will see a large hole the fluid uses to feed the piston. Now look more closely and you will see a tiny pin hole that returns the fluid back to the reservoir. This is plugged . Clean this pin hole with a piece of wire ( one wire cut from a wire brush will do ). Fill and bleed the system and your problem should be solved. If the bike is old you should replace all the rubber seals in the master cylinder and wheel cylinder (You probably don't need them.)
May 13, 2010 | Motorcycles
How do you changse the timing belt on a dodge
To replace:
  1. Remove pax wheel, splash guard, power steering pump, motor mount, crankshaft pulley, plastic covers (3).
  2. Before removing, clearly mark timing belt and pulley with paint marker because overhead cams will move it engine is not at top dead center. Remove tentioner pulley and remove belt.
  3. Compress piston rod with clamp and hold down with small allen wrench through pin hole.
  4. Replace belt, then tensioner pulley with pin still in place.
  5. Remove allen wrench and good luck. Install everything in reverse.
  6. Tedious but possible for anyone with some mechanic experience.
Feb 10, 2010 | 1997 Dodge Avenger
I have antifreeze leeking out a pin hole under the water pump
It is very likely the water pump seal. It is always a good idea to replace the bearing while you have it opened up.
Jan 13, 2010 | 2002 Honda CRF 450 R
Move timing cover with the motor still in the car. go behind harmonic balincer
sounds like you have had a frustrating time.... sorry to add to it.... i believe the balancer has to come off to replace the timing cover.
Robert
Sep 27, 2008 | 1992 Cadillac DeVille
Water pump 1995 nissian maxima
First you need to take off all the belts, then remove the a/c line to axcess to the 8 mms bolts holding the upper and lower timing belt covers. To facilitate the job you will need to remove lower crankshaft pulley.
This is a delicate job, since you have to access to the cam belt, I suggest buying the haynes manual for your car and following the step by step illustrated procedure, before starting the job.
More websites on this:
haynes manual, inner fender
Replacing Your Water Pump - Popular Mechanics
Sep 07, 2008 | 1995 Nissan Maxima
Psi Sistema GT11 1400 PSI Pressure Washer Logo
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
