Question about Gateway P-6831FX Notebook
Gateway p-6831fx not connect to external monitor
Will not connect to external monitor
  • mark Oct 26, 2012
    i used to have it connected all the time to my flatscreen, it was great...since i got windows 7 it doesnt even recognize when i plug in the vga..its really a bummer cause i dont have cable and watch everything from here..the only thing im finding is that maybe i need a new video card
    Problem Solver:
  • 5 Answers
Have you connected it before, or is this your first time trying? I know that some laptops have different function keys you must press for the screen to appear. Try fn f8, fn f7, fn f9. It depends on the computer. Hope I helped.
Posted on Oct 26, 2012
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
Ho do i connect external monitor to my mt 3422
Most laptops have a 15pin video connector to allow an external monitor to be attached to the laptop. Power up the external monitor first and then boot up the laptop, the video information will automatically switch to the external mpnitor.
Mar 04, 2012 | Gateway MT3422 RTL Notebook
My laptop Gateway ml6720 has a black screen Ive replaced the battery and power adapter no change. The fan comes on and it sounds like it boots up but no screen.
Sounds like either the screen or the video adapter has gone bad.
Do this: Connect the computer to an external monitor (there is a SVGA plug on the side of the computer. Be sure when you turn it on that you press teh Fn-special function key combo that switches the video output to the external monitor. If the external monitor works, then it's your computer's screen. Possibly the inverter. If the external monitor shows nothing, then it's the video card (which may be built into your motherboard).
Oct 05, 2011 | Gateway Computers & Internet
Monitor only works in safe mode, how can I do a recovery in safe mode. Recovery in a partition
If your monitor only works in safe mode, try to reinstall your video card driver while in safe mode.
Hope this helps.
May 27, 2011 | Gateway P-6831FX Notebook
My gateway monitor It does not power up at all???? any suggestions??
Hi Friend, In this case I would recommend you to please first of all unplug all the wired connections from the back of the system even the connection from the monitor to cabinet. Now press and hold the power button of the cabinet for 30 seconds and replug all the connections back again. Restart the system.
If it still doesn't work then check if you are getting any spinning sound of hard drive so as to check if the internal components are working fine.
Also connect any external monitor to the cabinet and check if you have the same issue with the external one as well?
Please let me know if it was of any help?
Jan 04, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
THE MONITOR ON MY ONE PIECE GATEWAY PC IS BLACK BUT THERE IS POWER TO THE COMPUTER. TRIED PLUGGING IN AN EXTERNAL MONITOR BUT HOW DO I GET IT TO WORK WITH THE COMPUTER?
Addressing this as a Gateway 4540GZ PC Notebook. If it is a different computer please state in a Comment.
Gateway Support > Gateway 4540GZ main support page,
http://support.gateway.com/s/Mobile/Gateway/4536GZ/4356nv.shtml
User Guides > Click on > 8510221-Gateway Notebook User Guide
Page 31 - System Key Combinations
Press the Fn key, and the F4 key to toggle over to an external monitor.
(External monitor plugged into the VGA port on the back of the laptop, and turned on,
VGA port,
http://en.wikipedia.org/wiki/VGA_connector
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Nov 02, 2010 | Gateway 4540GZ Notebook
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
Gateway P-6831FX Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
