Had power surge. Tv was on surge protector. Now no power will come on and just makes a buzzing sound.
    Scholar:
  • 152 Answers
There is a short in the main supply inside your TV.
The short is causing the switching power supply to switch on and off faster and harder, trying to work. That is why it makes the ' buzzing ' sound.
The surge protector did work, but the damage was done in the 3 to 7 milliseconds that it took the surge protector to limit the voltage and current. Everything takes time to work. When you turn on the light switch in your room, it takes a certain amount of time for the electricity to get from the switch to the light bulb. When you are driving and you step on the brake, the car does not stop immediately.
Posted on Jan 09, 2015
    Problem Solver:
  • 8 Answers
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Posted on Oct 26, 2012
SOURCE: Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
Posted on Feb 29, 2008
The Slash
  • 53 Answers
SOURCE: no picture and sound
Hello there
The issue that you are descibing sound it a bad small signal board which needs to be taken to thr repair shop.
Posted on Aug 09, 2008
SOURCE: Pioneer Plasma TV powered off and won't power back up
Power supply failure-checked Pioneer's website, there is a recall on the power supply.
Posted on Nov 18, 2008
budmrtn
  • 11361 Answers
SOURCE: power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Posted on Oct 31, 2009
SOURCE: My TV will not power on at all today. It was
it has (2) 8 amp 250 volt ceramic fuses, slow burn, 5mm x 20mm that needs to be replaced. they cost about $1.00 - $3.00 each. Just take off the back cover (make notes of where the 4 different types of screws go!!!) and look just above where the plug goes into the tv. A set of needlenose pliers will easily remove the fuses.
Posted on Dec 03, 2009
Loud pop from surge protector that results in intermittent sound on Samsung 46" tv
I hope the surge protector is separate from your TV. It has Varistors in it that are supposed to pass overvoltage surges (it can happen without the power going out) then recover to normal. But sometimes they overheat, then they can become a fire hazard. Or the contacts in the sockets can get charred and flakey. Anyway sounds like it is fried, the only easy solution is replace it. A careful tinkerer with a good scrounge box could fix it, if you know anybody like that.
Jan 03, 2014 | Proton MM2701VT 27" TV
Buzzing tv after power surge
Get the estimate. When your insurance company sees it, believe me, they won't buck at replacing your TV _especially since the prices of TV's have come down over the years while the quality and resolution has skyrocketed. . .
Jul 28, 2017 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
A buzzing humming sound improves greatly when in bypass mode. most of the sound seems to come from the center channel.
Ensure that the source cables are not touching/crossing power cables, and make sure the power source is clean(surge protector/regulator).
Jan 17, 2011 | AudioControl RIALTO Home Equalizer
My Panasonic TV/DVD/VCR Combination has a dull buzz sound on all channels. How can I stop that Dull Buzz? Model number PV-DM2719. LBV
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 17, 2011 | Panasonic Televison & Video
Power surge hit my surge protector with my 'sony tv hooked to it.
Oct 31, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Sony Grand WEGA KF42WE610 42" turns on and off
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Apr 04, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Televison & Video Logo
286 people viewed this question
Top Televison & Video Experts
Electro Med Services...
