HEATER WILL NOT STAY LIT
PILOT LIGHT WORKS GOOD , BUT WILL NOT LIGHT UP ON HIGH SETTING
  • 3 Answers
This happened to me as well. my pilot light had 3 settings.
"off" which is in the middle.
"up" is for priming/starting the pilot light.
"down" is what you move it to AFTER the pilot light is lit.
prior to lighting the pilot light, I had get city get city to verify gas was coming into house. It was not. someone thought they had turned gas on, but in fact did not.
so I had two problems.
Posted on Oct 25, 2012
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Oct 22, 2008 | Cozy Enclosed Front Console Heater 70,000...
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
