Question about Car Audio & Video
I have a Sony cdx-gt510 my eject button broke off,
I have a Sony cdx-gt510 my eject button broke off, what can I do to be able to push the button to make it work please I need help!
Pterocarpous
  • 202 Answers
SOURCE: Sony CDX-MP70 Face Plate Controls
Hello Duncmeister
You can find Sony's listing for this device HERE.
It there is an issue w/ the bezel (face) interface, it may be possible to replace that sub-assembly. It's doubtful you'll be able to actually repair the hardware problem w/out replacing a subassembly as the problem is likely a failed electronic component.
Your best bet for resolving this problem, I believe, will be to get a warranty repair or replacement for the unit. There are no repair parts listed for this unit so, likely, you will need to send in the entire unit for warranty service. Sony's pretty decent about this, though, so, definetly consider that option.
HERE is Sony's support page for consumer products. Have your unit's serial number and model number handy when you contact them.
** Please, remember to provide ratings for
** the experts' solutions (once your issue has
** been resolved)
** You can assing the same rating to more
** than one expert if you like - Even a "FixYa"
Thank you,
BJ @:)
Posted on Apr 11, 2008
SOURCE: Sony CDX-M630
I had the same thing.
Cause was faulty ribbon cable (hence no display)
and reset, which causes no response except to beep when you press open button.- display would have said 'code in' had it worked
Posted on May 16, 2008
SOURCE: i have power going to the unit yet there is no
I have a Sony CDX GT 530U. I had a problem with no display and I thought no power period. I did not try to install a CD, so maybe I did have power to the CD motor but no display. This was frustrating because I could get the old factory Nissan radio to power up and work so I thought I had a dead Sony unit. After a lot of monkeying around, I discovered I had blown a fuse while installing the unit (you should disconnect the negative terminal of the battery when installing the radio... which I thought I skip, that was a no no.). I had checked the auto fuses, those cheap little plastic fuses behind a panel below the stearing column inside most cars, at least all the fuses I thought went to the car stereo. Turns out I missed one that was labeled "Batt" or something like that, which was the constant power wire to the car stereo. There was another fuse for the Accessory power to the car stereo (the main juice went the key is tuned to ACC or Start position). Turns out the Sony unit display runs off the constant power, or at least the unit on/off button runs off the constant power wire, so even though the ACC power wire was live, the Constant power wire had a blown fuse and the unit would not turn on. Check all your fuses inside the car, I bet that's your problem. Constant power on my Nissan Sentra was a 7.5A fuse, while the ACC power ran off a 15A fuse, but your vehicle may vary. Good luck.
Posted on Jul 18, 2009
SOURCE: how do you change the time on a sony cdx-gt510
Push & hold down the volume knob until "clock adj" appears on the face (a couple of seconds). Then turn the volume knob, left or right, to adjust the time up or down
Posted on Dec 01, 2009
SOURCE: Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Posted on May 10, 2010
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
I have a snoy cd player that i hooked up with a wiring harness i bought from the store. I lost my old one. They told me that the harness will work but after connecting everything the cd player won't work....
you may need the ilumination, pleas google your car model year and brand and the words "stereo wiring diagrams" and you'll may find the correct wire distribution of your car
Mar 23, 2011 | Sony CDX-GT510 CD Player
Where is the eject button? in my cdx m8800
On the link below click on owners manual then on page 5 will show you the eject button. #24.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXM8800
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 10, 2010 | Sony CDX-M8800 CD Player
How do you change the time on a sony cdx-gt510 stereo
Nov 28, 2009 | Sony CDX-GT510 CD Player
I need a wiring diagram for this stereo
Click Sony Support to download installation manual of CDX-GT510 CD Player.
Jun 03, 2009 | Sony CDX-GT510 CD Player
Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Oct 02, 2008 | Sony CDX-S2200 CD Player
Sony CDX-M630 CD Player Problem
Mine did the same...it will stop working all together soon...repace the ribbon you should be fine
Apr 22, 2008 | Sony CDX-M630 CD Player
Cds stuck in sony cdxt69
Take power away for 5min then plug back up. Hit reset with pen head.
Sep 17, 2007 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
