Question about Balboa Instruments Duplex Digital Panel 2 Pump
How to fix balboa EL2001 spa
I got an OHH on my spa, I replaced both sensors, what else could it be? and how do I fix it
    Scholar:
  • 111 Answers
OHH would be the Hi Limit sensor. OHH is an overheat event...
Check the followng:
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter.
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
As you have already changed the sensor it is likely to be one of the others points. Hope that helps.
Posted on Oct 31, 2012
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: error code "OHH" displayed when
OHH code means "Overheat" condition
The spa has shut down -one of the sensors has detected 118 ° at the heater. Check it and replace it if go to bad.
Hope helps.
Posted on May 25, 2011
SOURCE: I need to replace my
The best suggestion in this case would be to replace the spa pack and upgrade. this is a really old system. You can replace the entire system for around $500.00 and have the latest working technology along with a new topside panel, overlays, heater, system, etc. The Balboa Value Pack Retrofit kit comes with everything you need along with cables. Since you have Weslo with an oval panel, the best suggestion would be the Balboa 54219-Z Value Pack Retrofit Kit. you can get it online by clicking on the link I have provided.
Hope that helps.
Balboa Direct
Posted on Sep 12, 2011
My balboa spa is not heating everything seems to be working fine what could be wrong
check fuses for heater element if ok see if calling for heat if so check element if not calling for heat bad temp sensor replace
Sep 08, 2015 | Balboa Instruments Pool & Spa
I have a Jacuzzi spa with a Balboa R576 (522205) control box. The control panel constantly shows "OH" (overheating) even when the water temp is 50-100 degrees F. When I reset the system by flipping the...
There are some things to check.
Make sure the vents on your cabinet are not obstructed.
Make sure your filter cycle is not too long
Make sure you are not running high speed for more then 30 mins.
Have you looked through the Balboa error message site. I have attached a link follow your error through and you may find your answer. Diagnostic Messages
Mar 02, 2015 | Balboa BB58048 Jacuzzi R574 R576, 4.0KW,...
Sensors on my dream maker spa is not working
If you have an Ohm meter you could test the sensors to see if you're getting the correct resistance. It is most likely that they have failed.
Most Dream Maker Spas have Balboa sensors which aren't too expensive, it might be easier to replace them.
Aug 08, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
I need to replace my Weslo Spa Comand Panel, 4 button, ovel. will the Balboa work.
Hope that helps.
Balboa Direct
Sep 10, 2011 | Balboa Instruments Duplex Digital Panel 2...
Error code "OHH" displayed when
Hope helps.
May 25, 2011 | Balboa Instruments Duplex Digital Panel 2...
When I put power to my unit. A Sn code appears. Great Lakes spa 1996 260E balboa wiring
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Dec 06, 2009 | Balboa Instruments Garden
Balboa Instruments Duplex Digital Panel 2 Pump Logo
257 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
