Question about Dryers
I can not find model number or serial number on my roper gas dryer
  • nguyenpho Jan 03, 2009
    My dryer when I push the start button and the dryer can not start.
    Can you help me how to solve this problem.
    Thank you
  • 115 Answers
NOTE: Some of the parts shown may not be for your appliance
The model number from your search was either missing or incomplete.
· Choose the best fit from the Model Number box to the left, or
· Check your appliance again to obtain a more complete model number
· To continue without a model number, use Narrow Your Search options
· Some models always have 3 numbers first, like this (123.456789)
// Model Number Locator Tips
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag. Gas Electric Whirlpool Style 1 Gas Electric Whirlpool Style 2 Gas Electric GE Style GE Electric Maytag Style I can not find model - gaselectricwhrilpoolstyle1.jpg?ver=15
Posted on Jan 03, 2009
4 Suggested Answers
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
heatman101
  • 43501 Answers
SOURCE: I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Posted on Mar 30, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer is about 7
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 23, 2010
How do you find the model number
open the door and look around the opening where you put the clothes into the machine,you'll see a tag with the model and serial numbers on it.
Dec 11, 2011 | Roper REX4634KQ Electric Dryer
What year is a Whirlpool (Roper) dryer Model # REX5634KQ1 Serial # MM1558692
The second digit/character of the serial number indicates the year and the two digits next to it is the week the appliance was made. Refer to the table below.
In your case, the serial number is MM1558692. The second digit/character is M and the two digits next to it is 15. Based on the table, the machine was made on the 15th week of 2002 or April 2002.
Feb 11, 2011 | Whirlpool Dryers
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
heatman101
Aug 23, 2010 | Whirlpool Dryers
Roper dryer ignites then shuts off
You need to replace the coils (comes 2 in the kit ) on the burner valve .Remove the front panel and the 2 coils on the valve are hold on by a bracket with 2 screws . Unplug the coils (no need to turn off the gas ) and replace , makeing sure the little dot is in the hole atop the bracket . When the coils get hot from electricity going thru them , one will "short" internally , until dryer cools down . Then will work for a short time and stop heating again . When you go to get the coils , take the model number off the plate (open the door and there will be a model/serial number ) and take it with you . If you had listed the model number here , I would have given you the part number .
Aug 16, 2009 | Whirlpool Dryers
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer not working
If the drum will not rotate, look for a broken belt or even possibly a faulty motor. If it is a belt, it should be relatively cheap to repair and possibly easy for you to aquire the specs on the breakdown of the dryer to access the belt for installation. If the belt isn't broken, then the motor is possibly shot and I am unsure of how much ROPER parts are. Be model number and serial number SPECIFIC when ordering parts, and don't go with the "SUGGESTED MATCH" just to save money if you can avoid it, they aren't always compatible.
Mar 14, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
251 people viewed this question
Top Dryers Experts
