Question about Samsung SyncMaster 2233RZ 22 inch 3D LCD Monitor
Are this capacitors broken??
I have the "1 sec black screen problem" and after opening my monitor I found that the common issue (the capacitors) don't look actually bad. http://www.mediafire.com/conv/520d476d9ad61e8e36d3151fccdcdd4e20523e6eedea0415aa0352dcff6ee6cc6g.jpg http://www.mediafire.com/conv/6b434674ffdaa080203b19d462abb923eb301f373b8fa1f1bdf3e5c36f45e8fb6g.jpg I'm not expert, and this is my first attempt to fix something like this. So... any help will be welcome. Thanks in advance.
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Hi, I got problem with my 226BW Samsung. Some
Sorry, the links you provide does not work. You can post the picture her at FIXYA but it has to be less than 150k in size.
Do you see caps with dome top (not completely flat)?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 12, 2011
Testimonial: "Thanks for your help"
Samsung 920nm sync master Black screen
Samsung sync master monitors were well known for bad capacitors, if you have a esr capacitor meter you can check in circuit, if not look for dome shape at the top of the capacitor, a dead give away it is open, also check for poor solder connections in the power supply inverter board area.
Jun 20, 2012 | Samsung Computers & Internet
Monitor comes displays Acer logo and goes black after 3 seconds, with indicator light still green.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Screen flashes on 1 sec and off 1 sec.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Oct 05, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
My samsung t240 screen turns black after 2 secs to an almost black screen, could it be a problem with the fuse as the monitor still has power??? plz help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 13, 2010 | Samsung SyncMaster T240 Monitor
Screen Comes on and goes blank within 3 sec
Look for bad caps (bulging/leaking tops) in the power supply first, it may have taken out the fuse and transistors in the inverter circuits also.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 26, 2010 | Westinghouse L2046NV Monitor
My Viewsonic VX724 LCD monitor just died, power button flashes green and flickers in between flashes, screen is black, any sugesstions? I opened it up and found a couple of capacitors domed and black stuff...
The domed capacitors are the cause of your power issues. If you replace them you should be back going again. If you are interested we do offer a repair service for $30.00 pus return shipping to repair your monitor.
Oct 09, 2009 | ViewSonic VX724 17" LCD Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
E153FP Monitor screen goes black light is green
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Oct 23, 2006 | Dell E153FP 15" LCD Monitor
Samsung SyncMaster 2233RZ 22 inch 3D LCD Monitor Logo
85 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
