Question about Rheem 81VP20S/430157 Water Heater
6E50-2 anode rod location - Rheem 81VP20S/430157 Water Heater
4 Suggested Answers
  • 126 Answers
SOURCE: location of anode rod in
theres a plug on top of the heater, the rod is under that plug
Posted on Jan 14, 2011
SOURCE: where is anode rod located on 100 Gallon rheem
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
http://waterheatertimer.org/Replace-anode-rod.html
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 22, 2011
SOURCE: Where is the anode rod
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
http://waterheatertimer.org/pdf/Rheem-Ruud-anode-rods.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
http://waterheatertimer.org/images/Water-heater-anode-006-200.jpg
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Posted on Apr 01, 2011
Anode replacement. where is the anode rod located on a ruud g100-200 gas water heater
either in the anode port on top of water heater, or connected to hot water nipple as a combo ... or both if unit has 2 anodes
Gene
Sep 25, 2014 | Rheem ruud g100-200 water heater,gas,100...
I can not find the anode on my water heater
1) Copy following link:
2) Anode might be located on hot water nipple as a combo.
Insert carriage bolt when removing nipple to avoid collapsing nipple during extraction.
Regular combo anode rods are available, or buy sausage-link combo available in 12" length to fit low headroom installations.
3) Ordinary 1-1/16" hex Anode might be located under the metal cover on steel tank.
4) If unit has power vent, the anode might be under power vent.
Workaround; Install combo anode to replace hot water nipple.
Dec 06, 2012 | Whirlpool Water Heaters
How to replace anode in Reliance 6402ORS
Anode can be connected to, and part of hot water nipple.
This is called combo anode rod.
http://waterheatertimer.org/images/Anode-top-of-heater-600.jpg
There are also instances where the anode is on top, but does not line up with access holes.
This is more typical with older water heaters.
Don't forget to clean air intake located on bottom of unit, using feather duster or compressed air.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Year of manufacture for Reliance is 2nd and 3rd digit of serial number located on label on side of tank.
Reliance is owned by AO Smith.
Nov 29, 2012 | Reliance Water Heaters
GPS-75-200 anode replacement
The anode is located under the power vent.
Remove power vent to gain access.
Otherwise, remove Hot water nipple and install combo anode rod. If odor is the reason for replacement, then installing a combo without removing the old anode will not solve odor problem until old anode completely dissolves over time.
Copy following link for specific information and illustrations, including odor elimination using hydrogen peroxide.
For easy access next time, you can remove old anode and plug hole, and then install combo rod.
If longevity of tank is reason you are accessing the anode, you can add a second combo anode in addition to the original anode and give longer protection
Aug 07, 2012 | RTO W4 A.O Smith Gas Hot Water Heater...
Where is anode located mdel no. 82yp30-1
Question posted under Rheem water heater.
Model number does not describe water heater.
Model number posted in question does not appear at Rheem, and does not appear in a web search for water heaters.
Here are options:
1) Add a comment and describe water heater in detail so expert can access more information
2) Contact Rheem.
http://www.rheem.com/Contact.aspx
3) If this is tank-type water heater, the anode is located on top of heater.
Look for 1-1/6" hex nut located under a plastic plug.
Some anode rods are connected to the hot-water nipple.
Sometimes the top cover has to be removed to find anode hex nut.
I have used impact wrench on anode, and could not remove in some cases.
4) More resources:
Sep 17, 2011 | Rheem Water Heaters
Where is the anode rod located on the rheem 81VP20s
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Where is anode rod located on 100 Gallon rheem water heater natural gas
Mar 22, 2011 | Rheem Water Heater Anode Rod AP12938
I have a 30 gal electric reliance 501 240 volt 4500w . getting sulfur smell. I can not find rod to replace.
Anode rods are located on top of tank:
Open links below and watch video.
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
Top of tank has access to anode, but you might have to take metal top off of tank.
Sometimes product manual has details about location, but drawings in manuals are usually generic and not fully informative.
I suggest loosening anode rod before installing tank so the rod can be easily inspected each 1-3 years.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 14, 2011 | RELIANCE ELECTRIC WATER HEATER
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
Cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Sep 30, 2009 | Water Heaters
Rheem 81VP20S/430157 Water Heater Logo
317 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
