Question about Kenmore Dryers
Kenmore dryer 66812690 over heating
My Kenmore dryer 66812690 keeps turing off after about 20 mins and the close are still wet. It smells hot when I check on them but it won't restart the cycle until I let it sit and cool. Then the same cycle happens again. I just had the dryer duct work cleaned professtionally and it was plugged at the roof vent. This allows the dryer to run for 40 mins now but will still not complete a full cycle.
    President:
  • Kenmore Master
  • 1,922 Answers
Did you clean the inside venting circuit inside the dryer from the blower housing.lint trap etc if the dryers full of lint a clean outside vent system wont help
Posted on Oct 26, 2012
  • 184 Answers
SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Posted on Apr 10, 2008
SOURCE: kenmore dryer stops
does the motor hum when you push start? if so then your drive motor is bad.
Posted on Nov 11, 2008
rickzilla
  • 706 Answers
SOURCE: Heating element won't stay hot.
Hello vsjant3,
I assume you cheated out the door interlock switch when running your test. If you did not, then the dryer will shut off when the door is open as part of the safety interlock system. If you did cheat it out and the element shut off after about 20 seconds, then you may have a problem with one of the temp sensors. When an overtemp condition occurrs, it disables power to the heater and it will shut off.. Other considerations are the wiring to the heater.. if you had a poorly tightened heater wire that was ok when first started and cold but when hot and passing current opened, that would also exibit the same symptoms. If I were a betting man, I'd say you probably have a bad temp switch. You can measure them with an ohm meter ( dryer unplugged of course).. or simply jumper the wires together to bypass one to see if it is the fault. Make sure you replace a bad sensor and do not leave it bypassed or you risk fire.
Here is a link to the wiring diaghram of your dryer.. http://www.pcappliancerepair.com/model-display.php
Hope that helps,,
Regards,
Rick
Posted on Jan 09, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore Heater not heating like it used to!
If your dryer IS heating, more than likely the heating element is NOT the cause. There are two thermostats that control the operation of the heating circuits. One, is the operating thermostat which regulates the internal temperature around 150 degrees and the other is the Hi-limit thermostat that cuts-off the heating circuits in an overheat condition of about 250 degrees. You can access the internal components through the lower front panel under the door. The panel can be removed by inserting a putty knife in the top seam where the panel meets the front cabinet about 2 inches in from each side. There are two retaining clips that you need to depress with the putty knife to remove the panel. Once the panel is removed, locate the heater box on the right hand side under the drum. The TCO and Hi-Limit Thermostat are located on the left hand side of the heat box. The Operating Thermostat (Internal Bias) is located on the blower fan housing under the drum. There are drawings available at searspartsdirect.com or appliancepartspros.com to assist you. Simply type in your COMPLETE model number (inlcude the "110." prefix) and you will find the heating circuits located under the "Bulkhead" heading. The Operating Thermostat (Internal Bias) is listed as item number 42, while the Hi-Limit Thermostat is listed as item number 48.
What you need to do first is determine is the blower fan housing is unobstructed. I know you mentioned cleaning your dryer, but did you also clean the INTERIOR. The blower fan housing can be a common point for lint to collect and restrict air flow. In addition (no attempt to insult anyone's intelligence here) are you making sure you properly sort your laundry when drying? More dense items, will take longer to dry and overloading can cause the same problem.
If your blower fan housing is clear, I suspect you may have a defective Operating Thermostat. If you wish to double check everything to make sure, the following link explains some common causes of dryer problems:
http://www.fixya.com/support/r385301-thorough_dryer_advice
If you have questions, or if you require additional assistance, please let me know. I hope this helps you solve your problem.
PS Even though I said I didn't believe the heating element to be bad, does not necessarily mean it is. They DO become weak with age and may not heat as well as they should. Double check the resistance. NOTE: Please ensure you UNPLUG the dryer before servicing. Dangerous voltages are still present with the dryer turned off. Also, make sure you disconnect any wire leads when measuring across components for more accurate resistance readings.
Posted on Jan 14, 2009
  • 13 Answers
SOURCE: dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Posted on Feb 27, 2009
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
66812690 need a part for this model of kenmore dryer
go to sears .com click on parts put your model number in and get your part-mike
Feb 17, 2010 | Kenmore 84052 Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Runs hot and smells
YOUR BELT IS PROBABLY BURNING UP
NEED TO REMOVE OUSTIDE HOUSING AND REPLACE
BEFORE TACKLING, HAVE SOMEONE TILT MACHINE BACK AND CHECK THAT NOTHING IS INTERFERING WITH TENSIONER PULLY
May 26, 2009 | Dryers
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
