Question about Yamaha Tyros 3 Professional Arranger Keyboard
What are the best settings on a Tyros 3 to play Chariots of Fire
Tyros 1 cutting out screen goes grey and restarts
Guessing that some people think a Tyros 1 is a PC or something.
If the Tyros goes blank screen and all the lights go out then it is most likely the REG board (regulators) that provide the 5v and 3.3v. This overheats and the devices shutdown. Quite often this is cured with a restart on more serious cases the regulators need replacing. As they are cheep it is best to replace all while the unit is apart. I am just about to do this repair on a Tyros I purchased the other day.
Feb 13, 2013 | Computers & Internet
Dvdfab v8.1.7.8 all in one serial
This is not a warez site. Sorry.
May 24, 2012 | Computers & Internet
I want to add orchestral backing to song
Build the orchestral as a MIDI file and then merge your song and send back to the Tyros to perform it. Building on an external machine you will find is easier than trying to do it all on the Tyros.
Sep 15, 2011 | Yamaha Tyros4 61-Key Arranger Workstation...
I need to replace the 3 1/2" floppy disc drive for
This should be easy enough to find with a web search on your part number... but it is very likely that almost any floppy drive will work, as long as it mounts in your location.
May 18, 2011 | Computers & Internet
How do I download a software update 1.02 for tyros 4 keyboard
go to the website of tyros and download the update for your keyboard.
http://download.yamaha.com/top/?site=usa.yamaha.com&language=en
then follow the instructions, you have to connect your keyboard to your computer.
Mar 02, 2011 | Computers & Internet
My Tyros 2 plays additional notes when I play chords particularly in C, G and E-Flat scales. The challenge is that I am living in the Caribbean and there are nor official keyboard technicians nearby. I can...
This is not something that spare parts would likely be needed for.
The first thing to determine is if in the piano mode that the unit first comes up in do you get this problem. If you do not, the UNIT is likely OK electronically. If you DO get the problem as a plain piano at start up, then one or more disconnect diodes (small 1N4148) are probably shorted. This is VERY uncommon occurence. These diodes are on the contact boards of the keys themselves. Contamination of metal such as a paper clip or metal shard could cause the same thing.
The Tyros II has MANY features and a lot of these create layers that fire other notes when using styles as part of the stylle rhythm.
The keyboard split features that allow the keyboard to act as three seperate ones can lead one to think there is a problem.
I have two Tyros I and one Tyros II and have worked on all of them as they were purchased as damaged and non-functioning. I have schematics on CD and those are available from Yamaha America parts dept in California. They are copyrighted but they will sell you the CD with schematics, etc. for about $15.
I can help you troubleshoot the problem if it really is a problem. The first thing is to see if problem exists in the piano mode at startup. If it does, then try each note in combination to establish a pattern. If a disconnect diode is shorted, you will find certain notes interact. You need to find which are OK and which causes problems... Defining the keys as problems in chords does not help as we need key numbers such as C3 or F#4. Do the searches ONLY using two keys at a time as a matrix problem cannot be diagnosed doing three at a time or more.
Aug 01, 2010 | Music
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
YAMAHA TYROS 3, THE SOUND WILL CUT OFF IN MID PLAYING. IF I TURN OFF KEYBD AND UNPLUG,THEN PRESS START BUTTON, (CLEARING MEMORY?), THEN PLUG BACK IN AND RESTART PROBLEM IS OVERCOME. SEEMS LIKE THIS PROBLEM...
I have Tyro I and II myself.
If somehow the registration is being bumped up or down during playing that would do it. VERIFY all the settings for the external pedal inputs regarding levels and function. Some of these can be set to do more than one thing. As a result, a pedal connected to the three jacks MIGHT be used for sustain and also triggering a step in registration number that is unwanted.
One needs to analyze the state of the unit when this happens...this should be possible UNLESS the whole thing including the data entry and display is freezing.
With the thousands of internal settings that are possible, it will be hard for us to give a definitive answer.
If you can afford to lose user created stuff, do a complete factory reset of the unit.
Apr 29, 2010 | Yamaha Music
How do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
Yamaha Tyros 3 Professional Arranger Keyboard Logo
20 people viewed this question
Top Yamaha Computers & Internet Experts
Carlos L. Burgos
Carlos L. Burgos
xalint1
xalint1
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
