Question about YouTube Videos
Can you show me a total knee replacement - YouTube Videos
Http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDMQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D6gHhhwQDZQM&ei=mhmLUPHYKaWT0QHu44CgCw&usg=AFQjCNGZ_mlsfBHB9JO4nx0aWOBZ1KVN0Q&sig2=Wg8b1Hl__4G7fBef4bIfZA
Posted on Oct 26, 2012
Where is the Mode Actuator Located in a 2008 Pontiac G6?
Preliminary Procedure
Remove the instrument panel left outer trim panel. Refer to Instrument Panel Outer Trim Cover Replacement .
Remove the left closeout/insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
Remove the data link connector.
Screws, Knee Bolster (Qty: 3)
Tighten
2 N·m (18 lb in)
Knee Bolster Assembly
Retaining Clip, Knee Bolster (Qty: 3)
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Screw, Instrument Panel Closeout/Insulator (Qty: 2)
Tighten
2 N·m (18 lb in)
Nut, Instrument Panel Closeout/Insulator (Qty: 1)
Tighten
2 N·m (18 lb in)
Panel Assembly, Instrument Panel Closeout/Insulator
Removal Procedure
Remove the fuse labeled HVAC CTRL (BATT).
Remove the left closeout panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
Remove the knee bolster. Refer to Knee Bolster Replacement .
Remove the mode actuator retaining screws.
Remove the mode actuator.
Disconnect the mode actuator electrical connector.
Nov 22, 2016 | Pontiac Cars & Trucks
Knee hurts
Mine to. Since I was in Junior high.
Oct 20, 2016 | Cars & Trucks
How Much Does a Total Knee Replacement Cost?
Here you will have explanation about total knee replacement surgery cost abroad http://www.youtube.com/watch?feature=share&v=zOcQVkcd52Y
Aug 16, 2016 | Cafe Press Knee Replacement Surgery coffee...
Hi can too much potassium cause fluid rention
go google and type in ---potassium and fluid retention---
the first site up states ---it may also benefit heart health (9)
potassium appears to help reduce water retention in two ways, by decreasing sodium levels and increasing u*ine production (10)
bananas , avocados, and tomatoes are examples of foods high in potassium
there are numerous sites that deal with water retention and the affects of potassium
as for your husbands condition, it would be far better to discuss the ongoing swollen knee and ankle and to ask if the potassium would help reduce the condition or would other procedures such as icing the knee when it is hot help reduce the swelling
I mention this because following a knee replacement, there is a lot of swelling in the knee and the specialist demanded an ice pack be used to reduce the heat ( the area around the knee gets hot during the healing process) and reduce the swelling
Aug 01, 2016 | Cars & Trucks
Vx commodore feul pump replacement
When you come on the top, you're now for you to lunge right down to the Other side. Come down until your leg knee is bent 90 degrees then break the rules back more. Again, you're NOT popping up to a total standing position - just straightening your hips and legs. This not only spares your knees, permits you to keep tension throughout the Muscle Building Review better AND use heavier prevention!]
http://www.tryperfectgarcinia.com/maxtropin-review/
May 03, 2016 | Cars & Trucks
I think I may be in the wrong place!
whilst pedaling, at the top of the pedal stroke, the knee should be positioned behind the axle of the pedal. This is so that as the pedal descends, the knee is not exerting damaging forces on the ligaments/joint. Force application should lead the pedal to go downwards without going hehind the position of the knee. This can lead to tendonitis should it happen for extended periods.
The position on many exercise cycles is wrong from what I have seen. I use a road/racing bike on rollers and that is how it is set up
I used to ride in a bad position and it did me a bad turn
To get max power the leg should be nearly....but not totally extended at the bottom of the pedal stroke.
Get a comfortable saddle, it really helps to be comfortable
stroke
Jul 20, 2015 | Exercise & Fitness
What can you tell me about knee replacement surgery
research this on the net and consult your orthopaedic specialist. It will depend on your bone structure (porous or not), age, your willingness to participate in rehabilitation exercises and your general health, Basically if you have a good surgeon ( check references ), are reasonable healthy (non-smoker, non -diabetic) and are not excessively over weight then most replacements have a success rate of around 85%. There is a process available where a lubricant is injected into the joint that is pretty good for a few months while you wait for the surgery. Again this is not the place to get information on such a serious subject so consult specialist surgeons( 3-4 second opinions) and be guided by them
Oct 01, 2014 | Cars & Trucks
How can I fix the knee lift that is very hard to push
how much srping tension do u have on presser ft. is the tension knob on top of machine screwed all the way down., never necessary by the way. next your arm attached to the knee lifter may be bent and not contacting the lifter bar for presser ft. get under machine and move knee lift with hand to see where contact is being made. bend accordingly. also the link from knee lift bar to link inside the back of the machine may be broken. u have to take off the back panel with all its screws. watch the gasket. you can replace the bar yourself since this will not intefer with the machine timing etc.
Jun 13, 2014 | Juki Sewing Machines
My aunt recently had total knee replacement for both knees. After a few days after discharge ,her body has swelled up especially her legs and face. Why?
FixYa does not have the expertise to answer medical questions.
I suggest you see a medical doctor ASAP to diagnose her condition as there may be some complications.
Jan 31, 2011 | Computers & Internet
YouTube Videos Logo
46 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
