Question about Refrigerators
I have a side-by-side refrigerator-freezer by whirlpool that is suposed to be automatic defrost but it is not working what can i do?
  • 76 Answers
That can be caused by a bad timer, bad defrost thermostat, or a bad heater
Posted on Jan 03, 2009
Freezer is too cold and icing over into the refrigerator - also makes a noise when the door is open and then shut. Refrig is not staying cold at all. HELP
It sounds like your automatic defrost cycle on your refrigerator is not working.
Try manually defrosting the fridge.
If this works then you will need to get the auto defrost repaired.
Mar 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
My ED5HHAXVQ02 refrigerator is not cooling. However the freezer is overfreezing and frost is building up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gs2shaxnl00 freezer working but not fridge not
The possibility is that the freezer fan is not working or the passage from the freezer to the refrigerator where the fan blows the cool air from the evaporator is blocked. Also if you say you manually defrost it could be that it is not self defrosting which can also cause this problem because the evaporator will build up ice and block the flow of the fan air
Jul 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Defrost side by side fridge
no you can not. there are no separate defrost control for freezer and fridge. the evaporator is located in the freezer section and it is supposed to defrost automatically. what is the problem in the first place?
Feb 08, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
