Question about Air Tools & Compressors
Free ingersoll rand air compressor p260wir wiring diagram
Wiring diagram
hdpanama
  • 65 Answers
SOURCE: ingersoll rand air compressor 185
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Posted on Nov 25, 2008
  • 1388 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 54 Answers
SOURCE: I have a Ingersoll Rand P185 WJD air compressor
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Posted on Nov 19, 2009
compman66
  • 169 Answers
SOURCE: i have a ingersoll rand type-30,model#2475 7.5
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Posted on Dec 06, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Need plug hook up diagram for 220 for Ingersoll Rand 2475N7.5 Type 30 2-Stage Air Compressor
Hi dcrouch537
Found these pictures on another webpage..
This should make your wiring much easier
"A picture is worth a thousand words" Please take time to rate mehunter19_46m_1.jpghunter19_46m_2.jpg
Sep 07, 2011 | Ingersoll Rand Type - 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Need wiring diagram for 'Low Oil Level Switch, part # 32276313.
trying to find diagram for you. LOLS will be wired in series with pressure switch.
Jan 26, 2011 | Ingersoll Rand - Rand Type - 30...
Need the wiring diagram for capacitors on a IR model 2475N7.5
Hi my name is Luke and I bought a Ingersoll-Rand 7.5 compressor and won’t start. I noticed it has a wire not connected on the capacitors it’s a blue wire that reads t5 v3 there’s a capacitor with open prong before two start caps and another capacitor after the two start caps , at least that’s what it reads on caps unless they have been wired wrong , being that I would think the start up caps should be wired first from powers supply box , want to know where it went Before I went trying to change capacitors and there’s 5 here’s a pic
Jan 01, 2011 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Air Tools & Compressors Logo
106 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
