Question about Dryers
I have a Whirlpool GEW9200LL1 Duet dryer. I replaced the thermal fuse since it would not start. There is no error msg but when I try to start the light stops on sensing and beeps. Is my motor bad?
I also made sure the door switch lever was not bent.
  • 1314 Answers
SOURCE: Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Posted on Mar 30, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 1738 Answers
SOURCE: Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Posted on Aug 11, 2009
SOURCE: the sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
Posted on Dec 23, 2009
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
Posted on Jul 17, 2011
Whirlpool duet dryer model WED8300SW0. dryer would not start replaced Thermal fuse. Worked a couple of cycles then won't start again. Replaced thermal fuse and thermister worked a couple of cycles then...
The thermal fuse is a safety so if you have an obstruction in vent line from the back of dryer to the outside the fuse will continue to blow until the airflow obstruction is cleared.
Mar 05, 2014 | Dryers
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Sensor light comes on when you push the start button but does not start spinning
This is a problem commonly caused by a blown thermal fuse due to a faulty thermistor or cycling thermostat depending on the model of the dryer. The thermal fuse is located on the blower housing and wired in series with the motor. The motor cannot therefore run when the thermal fuse blows open and no dryer functions works.
Unplug the dryer then remove the bottom panel and the lint duct and check continuity of the thermal fuse. You can also bypass the thermal fuse for troubleshooting purposes. Check for blocked lint filter and restricted vent system if the thermal fuse is indeed blown then replace it including the thermistor/cycling thermostat. Click on the link below for detailed troubleshooting of this common problem.
Kenmore Elite and Whirlpool Duet Dryers Not Starting
Jul 19, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
Jul 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool dryer GEW9200LL1 doesn't start
Has anyone changed the electronics console recently? This could be a user interface or software mismatch. The part number you should have on the electronic console housing for your model should be 3980093. If this part number is correct then checking each electronic component may reqiure an electronic technician.
Nov 12, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer (GEW9200LL1) Runs but is not heating
shelly makee sure both your electric breakers are on turn tham off then back on ck if you know how to ck 4 your 440 voltage if voltage is good the problem will be the heater element ck it are the thermo fuse eather one i founf thermo fuse more common problem
Feb 27, 2008 | Dryers
Dryers Logo
Top Dryers Experts
