Question about Electrolux Refrigerators
Electrolux ice maker - Electrolux Refrigerators
  • Official Brand Answer
  • 4,342 Answers
Hello - Do you have the model number? What is your concern exactly? Is the icemaker not producing ice or dispensing water?
Posted on Oct 26, 2012
3 Suggested Answers
  • 122 Answers
SOURCE: How to get ice make
call electrolux at 1-877-435-3287
Posted on Aug 22, 2010
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
Ice maker leaking
Hello Friend, thank you for your inquiry! I understand that water is
leaking from the ice maker of your Electrolux refrigerator; however please help me understand if you are referring to the ice/water dispenser (filter) or actual icemaker? With this material I can better address the issue at hand. Thank you! - Z
Jul 14, 2014 | Electrolux Refrigerators
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Electrolux ice maker bucket stuck
Probably the ice maker leaking caused by ice maker itself or faulty water valve. I would think you would have to let Ice thaw that's most likely holding bucket from coming out and then replace Ice Maker or water valve or both.
Aug 23, 2017 | Electrolux Refrigerators
Ice maker stops making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 23, 2010 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Electrolux EW28BS71IS ice maker not working
heatman101
sfgs
Jun 24, 2010 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Refrigerators Logo
69 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
