Question about Mitsubishi VS-50605 50" Rear Projection Television
Ripped outer screen
I was transporting my tv and the wind got between the outer grayish screen with ridges and the main screen and ripped it in half. I would like to know if this part is available, cost, location, and if this is a protective screen for the main one behind it
Trew Did you ever find a solution to your problem? I also need a TV screen. I lost mine the same way.
Posted on Jul 06, 2007
  • Mark Haywood Jul 06, 2007
    oopps
    Sorry forgot to include my email
    mahaywood@atlanticbb.net
Hisense LED TV Model 55H6SG has blue/grayish screen and won't turn off power, could this be the motherboard?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 24, 2017 | Hisense Televison & Video
I have a mitsubishi vs-60607. The outer screen was damaged during transport.. First, does the outer screen have a name or part number?Second can it still be purchased?
gona be hard
try the old white tooth paste trick
abit of soft scotch/rag with white toothpaste - scrub easly
should get it better
Dec 29, 2009 | Mitsubishi VS-60607 TV
THE SCREEN ON THE PANASONIC PT-53WX42F CRACKED WHILE MOVING IT
Depending on how bad, there are many layers of screen, if the outer layer is smooth and does not have ridges you can use a piece of Plexiglas to replace that. although glare may be more prevalent with a Plexiglas replacement. if the outer layer has ridges or more than one layer is broken there is not much you can do yourself. The screen from the manufacturer is cost prohibitive to replace. But if you have a local tv repair shop they may have a junk one, that they can sell you for a reasonable price. If it is just a small corner it might be better not to do anything at all, when you watch a tv it is the middle of the tv you watch and the corners are hardly noticeable under normal tv watching, although it may bother some people that the crack exists it actually may not cause you much discomfort watching the tv.
Oct 12, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Ripped screen on Zenith 52"Tv
email me at sissyh20@yahoo.com
we have one that dosnt work maybe we can part it out
Apr 29, 2009 | Zenith R57W46 57" Rear Projection...
Mitsubishi Model VS60607 Big Screen TV
There is a store called Big Screen TV Replacement Parts on EBAY that sells screens.
May 27, 2008 | Mitsubishi WS-65807 65" Rear Projection...
45" mitsubishi TV with gray/black "water stains" on screen
If the plastic screen has not been damaged by chemical properties in the liquids, the screen does not separate. Time will tell.
Apr 04, 2017 | Televison & Video
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-50605 50" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
