Question about Adobe Photoshop Elements 9
I can't find how to Cascade on Elements using "Expert Mode" Where is Expert Mode?
    Scholar:
  • 106 Answers
Modes are listed on the main screen of Adobe Photoshop Elements. Simply click on EXPERT to get into the expert mode.
The Expert mode has tools to correct color problems, create special effects, and enhance photos. The Quick mode contains simple tools for correcting color and lighting, and commands to quickly fix common problems, such as red eye. The Guided mode contains tools for basic photo edits, guided activities, and photographic effects. If you are new to digital imaging, Quick or Guided modes are a good place to start fixing photos.
If you've worked with image-editing applications before, you'll find that the Expert mode provides a flexible and powerful image-correction environment. It has lighting and color-correction commands, along with tools for fixing image defects, making selections, adding text, and painting on your images. You can rearrange the Expert workspace to best suit your needs. You can move, hide, and show panels, and arrange panels in the Panel Bin. You can also zoom in or out of the photo, scroll to a different area of the document window, and create multiple windows and views.
Posted on Oct 26, 2012
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Where is Expert Mode on Elements 9 to allow floating documents?
Expert mode is located above the document viewer. simply click it to enter into it.
Oct 25, 2012 | Adobe Photoshop Elements 9
Need to increase the recovery rate of Rheem 82SV30-2 elect water heater. Has 4500w upper and 3380w lower elements. Was told by County Health Dept that it was possible to wire both elements together for...
Basic information: Typical electric water heater operates in non-simultaneous fashion where either the upper element is ON, or the lower element is ON, or both elements are OFF, but both elements are never ON at same time.
Easiest way to increase recovery. If you have 10 gauge wire and 30 amp breaker, then install two 5500 watt elements. This will not work if you have smaller 12 gauge wire and 20 amp breaker.
Watt rating appears on side of each element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Change wiring.
If you run two separate 10 gauge wires to water heater, with each wire on a separate 30 amp breaker, then you can 'wire both elements together' to operate in simultaneous fashion. The elements are each wired independently of each other, but they can both turn ON at same time, and this action avoids heating lag if you also install larger 5500 watt elements.
Simultaneous water heaters can be ordered from manufacturer, and this is common with 80 gallon models where tank must keep up with larger demand.
Copy following link for illustration showing how to rewire for simultaneous operation:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
http://waterheatertimer.org/Tempering-tank.html
Aug 14, 2012 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
I have Reliance electric water heater 501: 40 gallon, 2x4500w. Where do I buy the bottom heating element? I went to the plumbing store and get one but it is a little smaller than the old one. why? I am...
Your water heater has two 4500 watt elements so water heater is 240Volts, and water heater is rated 4500 watts. Both elements are not ON at same time, and this is called non-simultaneous operation.
The element might have been smaller in length, but it will work fine.
Why is it smaller. I don't know. Elements are different from manufacturer to manufacturer.
The 501 does not use a special element.
Local box stores and hardware stores sell elements in water heater department.
The wattage of element is printed on end of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 20, 2011 | RELIANCE ELECTRIC WATER HEATER
Rheem 40 gal. elct. have 220 at both elements all the time but only one drawing?
Your testing may be off here. Or you might have special order 'simultaneous' wired water heater.
Water heaters with two elements are 240V.
Elements test for 120V at all times, but with ordinary non-simultaneous water heater, only one element at a time has 240. This is called non-simultaneous operation.
Open links below for understanding of water heater operation.
http://waterheatertimer.org/How-it-works.html
http://waterheatertimer.org/How-water-heater-thermostats-work.html
http://waterheatertimer.org/B220C.html
If both elements were drawing 240 at one time, then upper thermostat is bad, or else your water heater is wired for simultaneous operation, and one of the elements is burned out.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Your tank might be wired for simultaneous operation, if water heater was special order from Rheem, or if somebody changed wiring and set lower thermostat-and-element on a separate circuit breaker.
If you have simultaneous operation, then you would have 2 circuit breakers and 2 wires going to water heater or one 50 amp breaker with 8 gauge wire to heater. If this is the case, then both elements could test for 240V and one of the elements is bad, and thermostats are ok.
If you have ordinary Rheem water heater, then it is wired for non-simultaneous operation where only one element is ON at a time. This is called non-simultaneous operation and you can check because water heater has one circuit breaker rated for 20 or 30 amps.
Rheem elements are 4500Watts.
If both elements were ON at same time, that would be 9000Watts, which would trip typical water heater 20-30 amp circuit breaker.
9000Watts divided by 240 volts = 37.5 amps
So if upper thermostat is bad, and it is turning on both elements so they both test for 240, then thermostat is bad, but also one of the elements has to be bad.
Or test is inaccurate.
Interesting puzzle.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Dec 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Crusty sand type material stuck on the glasses
increase water heater temp, may need new elements
clean internal unit and screens
shop vac drain hose and pump and sewer drain
use cascade complete jel
Feb 03, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Detergent sticks in main wash compartment. We use cascade complete with bleach (hydroclean action). When this problem started, I switched to cascade complete (liquid) and still same thing happens. The...
Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 25, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Adobe Photoshop Elements 9 Logo
170 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
