Question about LG HBS-700 Bluetooth Headset
ONLY ONE SIDE OF THE HEADSET IS WORKING HOW DO I RESET THE HEADSET?
OR WHAT CAN I DO
Doesnt work from time to time
yes you must use the right batteries, try resetting it.
Jan 21, 2015 | Trust Radio Communications
SPH a920 CEL. Can't talk problem whit the cel MIC. Does work whit the HEADSET plugin. The cel MIC does works when doing the recording the voice test. Plugin in and out the headset the trouble was...
so the internal mic doesnt work, and now also the headset doesnt work either?
You can try a full reset on the phone I can email you the instructions on how to reset if you provide me with your email.
If that doesnt work then its a hardware side fault and needs to be serviced / repaired.
If you need more assistance let me know, I'm here to help
Apr 15, 2008 | Cell Phones
Neither 0000 or 1234 work as Motorola t305 passwords
I wasn't able to locate any documentation on a factory reset, but if it is like all of their headsets, press and hold both volume buttons and the call button at the same time - hold it for 10 seconds and it should reset - IF it works the same. If it does, the default passcode is 0000
Mar 07, 2010 | Motorola Mobility Bluetooth Hands-Free...
New Controller wont work with Headset
try to reset button on the both side (xbox and controller))
at same time it will work
for xbox reset buuton on the side censor
for joystick above the battery
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Treo 755 not able to make calls
The only workarounds I've read about these issues is:
1. Plug in the headset again and pull it out crisply and see if that works. Another method I heard, is to stick a toothpick in there.
2. Using the OEM Treo mono headset, insert the jack fully into the socket, spin the jack in the socket 180-360 degrees and remove the jack with a quick jerk. If the socket is truly undamaged, this technique, often repeated, seems to enable the speaker.
3. Some report that the headphone jack adapters, 3.5 to 2.5mm, work for this as well, that has NOT been my experience.
4. VolumeCarePro will bypass the headset switch and is a software workaround.
5. Otherwise, the only way I've been able to 'resurrect' the speaker is by hard reset, and once it took two hard resets.
As a result, I do not use my headset jack on my Treo 755p at all any more.
Unfortunately, this is an area that Palm is aware of, but has done little to fix.
is a hard reset
Jan 27, 2008 | Palm Treo 755p Smartphone
LG HBS-700 Bluetooth Headset Logo
66 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
