Question about Panasonic SA-HE70 Receiver
PANASONIC SA-HE70 ERROR F10 - Panasonic SA-HE70 Receiver
SOURCE: Panasonic SA-HE70 Sub Out Problem and Standby
hi i would try a new lead, try a normal audio phono lead , or at worst a dry joint at the plug on the amp, there are only 2 joints , so easy fix hope this helps. Ray
Posted on Apr 09, 2007
smarthome2
  • 1114 Answers
SOURCE: To smarthome2 Regarding the panasonic SA-HE70
Not very likely. Even to find one is a tough job. If you do find a source, expect to pay between 20-30 for it. I will look as well for you. If I find it, I will post the link or get a pdf if lucky!
Posted on Dec 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: how to hook up external
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
Posted on Jun 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a panasonic sa-he70
Page 16 of the manual has recommendations.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 27, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a panasonic SA-HE70 amplifier and all it
hi,.
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check that it gose Over load ( protection ) show or not . if not, then any of the speakers or its wiring have some problem. If so the reconnect the speakers one by one and switch ON the amplifer and check.find out on wchi speaker it shows lover load.
if the amplifer shows overload even after removing the speakers then you have to check the amplifiers hardware.
Also added the procedure how to check the amplifier satge. You should have a good knowledge in electronics to do the following. Also need testing instuments.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier have some problem. there are five amplifiers in this AV receiver. This problem occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components
OK
Posted on Sep 19, 2011
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
Nov 08, 2016 | Panasonic SA-HE70 Receiver
I have a button that allows bass/treble and balance but only balance works regardless of how many times you press it.
Read Page 13 of your owner's manual http://www.manualslib.com/manual/119549/Panasonic-Sa-He70.html?page=13#manual
Jun 06, 2015 | Panasonic SA-HE70 Receiver
Am looking for a manual for an SA-HE70 av control manual
Crutchfield has the manual for the Panasonic SA-HE70 on their product sale page: http://www.crutchfield.com/S-6TiEMal3qmL/p_133SAHE70K/Panasonic-SA-HE70-Black.html . Look at the Details tab. The direct link to the manual is http://www.crutchfield.com.edgesuite.net/pix.crutchfield.com/Manuals/133/133SAHE70K.PDF .
I hope this helps.
(You will need Adobe Reader or a similar program to read or print the manual.)
Apr 19, 2015 | Audio Players & Recorders
Its showing F70 error on display. Only workd on DVD mode, when i turn it on any other mode it just shows F70, switch power off. All fuses are ok, no any visibly damaged components
The fuse is a part of the problem it is for safety measures
the problem is in between the power supply regulators, capacitors and power amplifier circuit board.
usually a regulator or an output transistor can cause this error.
hope this helps.
Aug 08, 2014 | Panasonic SA-HE70 Receiver
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Jun 01, 2011 | Panasonic SA-HE70 Receiver
To smarthome2 Regarding the panasonic SA-HE70 overload issue. Is there any place where I can get a free service manual or schematic to troubleshoot this myself?
Dec 23, 2009 | Panasonic SA-HE70 Receiver
My receiver (SA-HE70) shows overload on the display, I know that someone probably shorted the speaker wires. How can I fix this or get a service manual for it?
Diusconnect all the speaker wires. Still overloaded? Y= take it in for service. N= isolate which speaker path is causing the problem.
Dec 11, 2009 | Panasonic SA-HE70 Receiver
F70 problem
Look up "Panasonic F70 error" on Google and you will find plenty of discussion about this problem.
The F70 is a blown fuse error. It looks like you can can the fuse yourself, if so inclined, otherwise send it to a service agent.
Aug 03, 2008 | Panasonic SA-HE70 Receiver
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
Apr 03, 2007 | Panasonic SA-HE70 Receiver
Panasonic SA-HE70 Receiver Logo
140 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
