Question about Sewing Machines
Where do i oil the janome sew mini - Sewing Machines
SOURCE: Janome M100 mini sewing machine
Providing you have checked to make sure the needle is in correctly, if the machine will not pick up the thread then the machine will need retiming.
Posted on Jan 22, 2008
mallow1
  • 35 Answers
SOURCE: Accessories for the Janome Mini Sew
Almost all of the Janome feet are interchangeable. Only a very few of their higher end electronic machines have special feet. So, if you ask for Janome feet, in general the stores give you the general purpose feet that work on most mechanical Janomes, such as Jem Gold, Decor, etc. Hope this helps!
Posted on Aug 16, 2008
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
  • 19 Answers
SOURCE: janome jf1012 owners / users manual to how to oil
visit us at www.janomestuff.com
Posted on Sep 16, 2009
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
My janome sew mini sewing machine is very slow can I fix it
First clean it thoroughly bobbin case included then oil it according the owners manual, i hope it be ok because the thread got caught in bobbin case and lint that causes it slow down.
Sep 25, 2014 | Janome Sewing Machines
Janome sew mini will not fill the bobbin
a part of the bobbin winder is not working and should be checked
Mar 25, 2014 | Janome SEW MINI Mechanical Sewing Machine
Is there somewhere I can order a replacement part for a Janome Sew Mini sewing machine? I need the little clear door that covers the bobbin compartment.
Try www.sewingpartsonline.com and put in Janome then your model number, they have all kinds of parts for sale. They may have your part or call Janome at 1-800-631-0183
Oct 04, 2010 | Janome Mini Compact
Type of needle for janome mini compact
Hi
Ask Jan on the Janome website.
http://www.janome.com/index.cfm/LearningCenter/AskJan
Or try on the forums there.
http://www.janome.com/fusetalk/forum/
I would imagine that Janome universal needles would be fine for this machine.
Thicker needles are required for sewing thicker fabrics.
Sep 19, 2010 | Janome Mini Compact
Janome sew mini will not pick up bobbin thread
Oil the machine first. Then, determine whether or not you need any parts at all.
Jul 03, 2009 | Janome Mini Compact
Owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Jan 25, 2009 | Janome Mini Compact
Jul 13, 2008 | Janome Mini Compact
Instructions
Try this website contact them if yours is not listed.
www.sew-europe.co.uk
Feb 02, 2008 | Janome Mini Compact
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
