Question about Maytag EPIC MFW9700S Front Load Washer
Front load maytag duet odor
Really stinks tried bleach, vinegar
  • 640 Answers
Well you have a filter down at your toe panel,,maybe it time to clean it..
Posted on Jan 03, 2009
    Scholar:
  • 140 Answers
Hello. This condition is usually cause by a build up of organic matter or there is no drain trap on the waste line that the water discharge hose connects to.
First check for slime and gunk in the big rubber gasket on the front of the washer. If there is some it's an indicator that you have a build up of active bacteria. This is real common in warm damp areas. The best thing to do in prop the door open on the washer and let it dry out for a day or so. If the smell goes away then it's just bacteria. Run a full load of hot water without any clothes in it. Put the washer on the largest load with extra water, if you have that setting, and the hottest water setting, hot wash and rinse.
When it is finished open the door and let it dry overnight. You may have to do this once a month or so. also when you are finished washing leave the door to the washer open to keep it dry. Good luck.
My soap tray is moldy, how do I clean it up?
pour some clorox or liquid bleach into it. Also run a wash of rags with clorox and vinegar a time or two and odors should clear up.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why does it makes my clothes stink like mildew?
The odor is caused by bacteria in the draining path. Run an empty clothes load with lemon bleach to get rid of the smell.
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My wirlpool duet front load washer stinks both when in use and not in use. how do I thoroughly clean and fix.
Is the odor simular to mildew? If so do you leave the washer door ajar after use? If not you should, it helps promote air circulation and helps dry out the inside preventing mold and mildew smells. I would run the washer on sanitary cycle or hot water cycle with bleach and baking soda. Then leave the door ajar from then on.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes and towels don't smell fresh after washing
If you are sure that the pump is not blocked then try running the machine on a quick wash on its own with a little bleach in the drawer.
Jun 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Neptune t.l. washer has a horrible odor that we have not been able to fix, either with bleach & vinegar solution nor with Electrasol lemon scent dishwashing powder, as has been suggested to us. This...
if you use liquid detergent for a long period this will cause a nasty smell and it leaves a horrid slime in pipework etc. if so, put on a boil wash and change to powder.
also, make sure there is a water barrier between the washer drain pipe and your house drains
Jul 11, 2008 | Maytag Washing Machines
Moldy odor
Try running it with just vinager and water no clothes.
Just put about a cup of vinager in it and wash cycle and another cup in rinse cycle.
Vinager is a better disinfectant and odor eliminator than bleach.
Mar 25, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
122 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
