Question about Archos Jukebox Studio MP3 Player
Bought new AC adapter but connected it with wrong polarity
I went to Radio Shack with my jukebox and AC adapter which cord was broken. Employee showed me adapter with same voltage and offered to plug it in to see if batteries would take charge. He connected the tip with wrong polarity and after a few seconds it smelled like plastic was burning inside. Now jukebox only shows "Jukebox Version:5.08" in the display but does not show me playlists as before. Is this something that can be fixed? Is there a fuse or something that can be replaced?
Thank you
Hate to ask the obvious but have you replaced the batteries?
Posted on Mar 30, 2009
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
Broken AC adapter
yes it can use it, as long as the polarity is the same.
Also the difference between 10v DC and 10.2v is not much at all.
You can go ahead and you use.
Best regards
Feb 10, 2010 | iSymphony CR1 Clock Radio Music System...
Where can I buy a replacement ac adapter for my pvs 133 dvd player
Radio Shack sell universal AC adaptors. Just be sure that you select the correct voltage and that the polarity on the power plug is set correctly. Most AC adaptors will have the center of the plug as +, but not all. The Radio Shack universal unit allows you to switch the polarity of the plug by just changing how it's connected on the end of the wire. Incorrect settings could destroy your player.
Aug 18, 2009 | Venturer 3.6" Portable DVD Player
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Power cord/AC Adapter
Unless your have some technical background and a multimeter, you are risking at least the battery pack of your laptop and worst case, the laptop itself.
Most devices that accept an external adaptor are somewhat protected against applying the wrong polarity of voltage but that protection is primitive and depending on the 'universal' (this really should be 'multipurpose-not 'universal) adaptor used, the protection itself can fail, exposing the circuitry inside the laptop that controls the voltage from the adapter to damaging voltage; this would get much more expensive than replacing the original adapter from the manufacturer of the laptop.
You did not mention the brand/model of laptop you have and with only the adapter listed, we can't help you much.
Mar 17, 2009 | Radio Shack Accurian APD-3955
Missing power cord/adaptor
You just need to go to Radio shack, and get a DC9V Adapter at 500mA and the correct polarity of (-) on the outside and (+) in the center. Original was a AHEAD AC Adapter Model ADB-0900500
Good Luck
Mar 14, 2009 | Cycling
Accurian Model APD-3955 Portable DVD player
I had the same problem. It turns out that my adapter for my Dell Digital Jukebox mp3 player works great. You might be able to order one from Dell. I hope this helps.
Aug 29, 2008 | Radio Shack Accurian APD-3955
Home plug in power cord
I would suggest Radio Shack or similar local electronics store that specializes in electronics for hobbyists(meaning Best Buy and Circuit City would not be my first choice). The trick will be to match the output voltage and amperage, which should be listed on the label attached to the unit (sometimes on the bottom) or listed on the old home AC adapter if you still have it. The other thing to keep in mind is the size of the plug connector which the adapter uses to connect to the unit. Take the unit to Radio Shack and they should be able to figure out which AC adapter is right for your unit.
Aug 22, 2007 | Durabrand Portable DVD
Archos Jukebox Studio MP3 Player Logo
205 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
