Question about Sharp AR-M620N Copier
SHARP AR M620N FUSER UNIT
HOW MANY TURNS DO THE FUSER UNIT SCREWS TAKE ON A SHARP AR M620N
sir fixalot
  • 146 Answers
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Posted on Jun 06, 2008
checkitright
  • 1362 Answers
SOURCE: Sharp AR BC260 color printing Lots of ghost lines in color prints
depends on what is the problem with it? if it's only toner on it, let it cool and clean w soap and water rag, then wipe clean. I suspect that it is most likely scratched and the coating on the fuser is missing, it should be a shiny smooth surface.
Posted on Nov 19, 2008
  • 67 Answers
SOURCE: H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Posted on Apr 09, 2009
taran_2005
  • 10515 Answers
SOURCE: Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Posted on Jun 11, 2009
  • 610 Answers
SOURCE: HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Posted on Nov 04, 2009
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
My sharp ar-m620n wont scan to email
Did you input all the necessary settings?
Sep 17, 2013 | Sharp AR-M620N Copier
F2-22
There is no code F2-22 for an AR-M620N copier.
Dec 04, 2011 | Sharp AR-M620N Copier
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
How do i reset the printer counter on a Sharp AR-M620 copier
Simulation 24-9 Used to clear print mode counter
Aug 16, 2010 | Sharp AR-M620N Copier
How to replace a pressurization fulcrum arm on the fusing unit of a Sharp ar-m 237 copier
The fuser needs to be removed from the copier first. If you have the part it is not to hard to take the fuser out. Turn the copier "OFF" first & unplug the copier, remove the transfer unit from the right side, then remove the back panel of the copier ( 5 screws ), then unplug the fuser unit ( 3 connector ) , then reove the top right cover ( 2 screws ), then you can see the 2 top screws & the bottom 3 screws, remove them and the fuser should pull out toward you. Replaced the broken fulcrum arm and reinstall the fuser in revese...... Good Luck
May 09, 2010 | Sharp AR-M237 Copier
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-M620N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
