Question about Microwave Ovens
The bulb blew out. I could not locate where the bulb is and what bulb to buy to replace it. Can you give me step by step where to locate the blown bulb inside this GE Spacemaker XL1800 microwave oven
    Problem Solver:
  • 18 Answers
Hello! Found the microwave manual: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40537.PDF
go to page 35-36, all the instructions are there!
Posted on Oct 25, 2012
What could be the cause of the oven light not coming on after replacing the blown bulb with a new bulb.There appears to be no power at the light fitting.I have tested this with a multimeter
maybe the bulb burnt violently and blew a trace off of main circuit board, if that happened, either find someone to repair the board or replace it
Mar 25, 2018 | Microwave Ovens
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Technika rangehood parts
    please follow the steps and fix it. God bless you
    1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
    2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
    May 27, 2013 | Microwave Ovens
    Kenmore elite microwave convection 721.67903 light bulb
    27oct: BKOK, replacing the light bulb is not simple, and requires a T15 security bit. Our microwave bulb blew this week, and sears on-line was not helpful, so I took the cover off and removed the bulb and the filament is blown. Here is what you need to do. Sorry, it's not easy. 1) remove the cover - this has 3 standard black phillips head screws, 2 on one side and 1 on the other. Then, there are 4 standard silver phillips heads on the back, plus two size 15 Torx screws that require a security bit to remove. 2) remove the 3 sided cover by prying the bottom and then pushing the cover towards the back of the unit to remove the latch keeping the cover secure to the front of the machine. 3) Now, there is a wiring diagram on the cover, use this to locate the bulb, but I will tell you it is on the top of the unit near the control panel. The white plastic connector has 4 wires going into it... Red, Yellow, Brown and Black. The bulb is secured with one screw and permanently attached to a trapazoidal base. The markings on my bulb say KEI, Korea, 125V,30W. 4) Remove the screw and lift the bulb assembly out and see if the filament is blown. The bulb is clear and so it's easy to see the filament. 5) I'm gonna go to local repair shop to see if they have replacements, but I usually go to AppliancePartsPro. They do have this bulb listed for under $5. , which is ok, but I hate paying shipping on such a small piece. Maybe I'll buy some other stuff. Good luck, it's not easy, and not a easy do-it-yourself bulb replacement. But if you are mechanically and electrically competant, it's not bad. But seriously, this is a lot of work to replace a light bulb. I'll take a picture and post that as well
    Jul 05, 2012 | Kenmore Microwave Ovens
    The hood light blew and I replaced it. It worked
    The cause could be anything from defective bulbs(least likely, to a bad bulb socket or vibration during operation. A voltage measurment at the bulb will tell you if it is getting too much.
    Eric
    Dec 24, 2009 | Microwave Ovens
    AFTER 12 MONTHS ON NO PROBLEMS IT WONT WORK. IT DOESNT GIVE ME DISPLAY LIGHTS OR ANY.
    most likely the internal fuse
    be soooooooooo carefull in replacing this , the capacitor inside the machine can store a huge charge
    1. Turn off all electricity to the microwave and unplug from the wall socket. Move the unit to a well-lit location to better see the appliance.
    2. Step 2 Usea schematic for the particular model of microwave being worked on tolocate the area containing the fuse to be replaced. Fuses can belocated behind the microwave door or behind a panel either on theinterior wall or an exterior panel. Often the fuse will be behind apanel located under the louver vents on top of the microwave.
    3. Step 3 Removethe panel according to the manufacturer's instructions. Use a screwdriver to remove screws and set aside for replacement.
    4. Step 4 Locatethe blown fuse and check with a voltmeter. This step ensures that theproblem with the microwave is indeed a blown fuse and not anotherissue. Check for current between fuse connectors.
    5. Step 5 Take the blown fuse to a local hardware or store such as Lowe's or Home Depot. Staff can assist in finding the exact replacement fuse for the model being repaired.
    6. Step 6 Placethe new fuse into the panel in exactly the same fashion as the blownfuse came out. Replace any panel using the removed screws and returnthe unit back to its proper location.
    7. Step 7 Plugthe microwave into the wall socket and turn on all electricity. Testthe unit by ensuring the clock and all other features function.
    Oct 21, 2009 | Emerson Microwave Ovens
    Blown microwave
    look for any disconneted wires.u could have pulled some wire while replacing the bulb.if every thing chks ok then it could be the control board.
    Aug 13, 2009 | Microwave Ovens
    Kenmore 63682300 Bulb blew now lights won't turn off
    See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
    Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
    Goldstar MIcrowave stopped working when light bulb blew out.
    when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
    Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
    Microwave Ovens Logo
    93 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
