I cannot pair the bluetooth devices together and the 0000 manual code does not work
SOURCE: Bluetooth Paired Up.
first turn on bluetooth and goto bluetooth settings and goto authentication and turnoff it.then bluetooth is connected
SOURCE: Pairing Problem with Cell Phone and Bluetooth earpiece
Not all bluetooth headsets are compatible. These are:
BlueAnt Wireless X3 micro Bluetooth Headset.
BlueAnt Wireless V12 LCD Bluetooth Headset.
BlueAnt Wireless Z9 Bluetooth Headset.
http://www.yourwirelesssource.com/buy/accessories/cat/28/model/1005_300368/accessory/291758?source=google_base
SOURCE: Default code for bluetooh pairing.
the most popular ones are 1234, 0000, 8888. If this doesnt do it then consult the user manual.
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
SOURCE: Can't find passkey for bluetooth. (0000 won't work)
hey ! you cant give random pass keys..you ll have to provide a pass key to the device to which you are trying to pair with..and that pass key must be entered so that your other device is safe..! so you provide your other device with a pass key ..then try..ok
