Washing machine agitates one way only
Hi I have a Simpson washing machine model # 22S740H.01. This unit only agitates one way resulting in washing being wrapped around the agitator, not washing or rinsing properly, can you help? We have grandchildren here for the holidays and really need it Thanks Regards Jim
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
Hi, we have Simpson top loading washing machine model number Esprit 550, the drum is not rotating and the spinning plastic rod in the centre of the drum is not spinning/rotating either
that is a direct drive
is the agitator (plastic rod )loose or sloppy
if you look down the inside of the agitator
do you see a nut at the base holding the agitator tight
if the timer is working
and water can pump in and out
that is good
bad
if you cant hear the motor click in
it will need to have the inspection cover taken off
for service or part replacement
May 20, 2016 | Simpson Washing Machines
Simpson agitator
I have the same problem, seems as if this washer always tangles the clothes, there is really no solution.
Aug 25, 2014 | Simpson Washing Machines
Simpson esprit 550 agitator & spin not working properly.
Open the lid during the wash cycle and observe the agitation, you need to see exactly whats happening, If its corkscrewing instead of agitating it will wind the clothes as you described. Agitation is usually back and forth, or up and down etc, not just turning constantly in the same direction.
Aug 25, 2014 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Dec 27, 2009 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing Machines Logo
900 people viewed this question
Top Washing Machines Experts
