Question about Mitsubishi WD-60737 TV
Wd-60737 mitsubishi blinking yellow status light ?
Changed lamp plugged tv back in and yellow status light blinking no power ?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Oct 26, 2012
  • AlphaOmega Jul 24, 2014
    According to the manual, a slow blinking yellow light means..."Lamp access door is not secure or no lamp installed. Yellow TV will not operate until lamp access door is secured. See Appendix D"
SOURCE: Red blinking status light on DLP Mitsubishi TV
how do you get the tv back on when the light keeps flashing
Posted on Sep 10, 2010
  • 375 Answers
SOURCE: Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Posted on Sep 12, 2007
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
  • 556 Answers
SOURCE: Solid yellow lamp light AND flashing yellow status light
start with the lamp.
Posted on Sep 21, 2009
SOURCE: yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Posted on Oct 23, 2008
Blinking code 3 2. will not turn on
error code 32 indicates the lamp cover is open, you might also check that lamp cover switch.
Mar 15, 2015 | Mitsubishi WD-60737 TV
It will not come on with a blinking yellow light and a code of 3 green and 2 green blinking lights.
Error code 32 indicates lamp cover open, also check the lamp cover switch
Mar 14, 2015 | Mitsubishi WD-60737 TV
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is...
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
My mitsubishi Model # WD-60737. It is lesss than a year old. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the wall for an hour....
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Jan 11, 2011 | Mitsubishi WD-60737 60 in. HDTV
Just changed the lamp and the "status" light is
you must install the lamp door after lamp replacement to get the "yellow" blinking to stop. if the status is blinking red then you may be having a fan failure internal to the tv. also make sure that the side filter door is installed and secure
Dec 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
Mitsubishi WD 60737 The TV arrived yesterday. We just set up everything tonight and the TV will not power on. When initially plugged in the yellow light on the front started blinking. Trying to reset...
If it is a Amber LED constantly blinking, I would double check the Lamp Door is secure. If it is a Green LED constantly, it is a problem on the DM Board or the Optical Block. In either case if it is brand new set, don't open the back, check with the Dealer to help get a Authorized Service facility to do a warranty repair on it. If needed, here is Mitsubishi's Customer Service line. 1800-332-2119
I hope this helps,
Skyassoc
Jan 07, 2010 | Televison & Video
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-60737 TV Logo
3,904 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
